Cant get into gear!!
Old Aug 22, 2007 | 03:28 PM
jaydem7's Avatar
Default Cant get into gear!!
this happened to me twice already!! ive tried shifting to first, sencond, even in reverse and it just wont go into gear!! whats going on here?? i dont think its the tranny because it doesnt grind or slip when im driving.. i hope its not the tranny....
Old Aug 22, 2007 | 03:47 PM
slowcivic2k's Avatar
Default Re: Cant get into gear!! (jaydem7)
Are you completely locked out of gear? As in you cannot shift to it period?
Does it grind when you try to shift?
You need to be as detailed as possible so we can offer useful help.
Old Aug 22, 2007 | 03:54 PM
9one9's Avatar
sounds like the car doesnt know the clutch is pushed in
Old Aug 22, 2007 | 07:51 PM
jaydem7's Avatar
Default Re: Cant get into gear!! (slowcivic2k)
well ive recently bought this car for about a month, ran fine untill yesterday. car started up fine but when i pressed the clutch in and tried to shift, it just locked me out. it wouldnt let me shift into any gear. so i rolled the car back and finally got it to shift to first. drove it home safely. then again today, it locked me out. i noticed that my clutch pedal was really low, like it would engage or start moving with not even depressing the clutch for like an inch. basically theres no play when you depress the clutch. does that make sense? is it my clutch? whats up?
Old Aug 22, 2007 | 07:59 PM
gsrhatch2356's Avatar
if it starts to move even when you have the pedal depressed it means that the clutch is not being dissengaged normally when you have a bad clutch it is due to excessive wear and wouldnt move the car even if you wanted it too so you need to look at the clutch master clyinder and slave clyider. always a good test but not perfect is to open the bleeder on the slave and have someone push the clutch in to see if there is any pressure at all but dont let the clutch up with out closing bleeder first. this will help with determining if it is primary or slave. if you have pressure try a slave clyinder first.
Old Aug 22, 2007 | 08:15 PM
jaydem7's Avatar
Default Re: Cant get into gear!! (gsrhatch2356)
the car doesnt move when the clutch is pressed down all the way to the floor. im just saying that it has a short release.
Old Aug 22, 2007 | 08:18 PM
MonsterB20Ek's Avatar
if it dont work try pumping the clutch a few times if it goes into a gear u'r slave or clutch master cylinder goin out? if not how many miles are on the car and did u ever change the oil in the tranny?
Old Aug 23, 2007 | 07:50 PM
jaydem7's Avatar
Default Re: (MonsterB20Ek)
bought it a month ago. i have no idea the tranny fluid has been changed.. but i pumped the clutch a few times and it goes into gear.. checked the fluids and its ok. not really dirty. its got a short shifter but i dont know.. im thinking about adjusting the clutch, cuz right now i cant feel any pressure when the clutch is pressed. so now my question is, how do you adjust the clutch?
Old Aug 23, 2007 | 08:04 PM
Default Re: (jaydem7)
You cant adjust a hydraulic clutch, all you can do is fix the problem so like stated try to determine if it is slave or primary then you should get your pedal back assuming that your clutch is still in pretty good condition
Old Aug 24, 2007 | 07:29 AM
jaydem7's Avatar
Default Re: (gsrhatch2356)
ive got a 96 dx. do they have hydraulic clutch or cable clutch? lets say i need to replace the clutch, what would you recommend? most bang for your buck..
Old Aug 24, 2007 | 04:51 PM
well you can get a stock one or for a little extra money get you like a fidanza flywheel and clutch, not to expensive and I got them and love it grabs so great you have to relearn how to drive cause its either on or off and you get great launches with it. the only I would stay away from is centerforce with the wieghts on the pressure plate. they are supposed to push down on the disc under higher rpms to reduce slippage but it makes a horrible noise when the clutch is depressed at low rpms.
Old Sep 2, 2007 | 04:30 PM
jaydem7's Avatar
update on the issue..
today, i went and inspected the problem more deligently and found that my clutch slave clylinder was leaking a bit... went to purchase a new one and BAM! problem solved... thank god i didnt buy the clutch.. and thank you for everyone's help!
Old Sep 2, 2007 | 05:12 PM
97Ej6mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydem7 &raquo;</TD></TR><TR><TD CLASS="quote">update on the issue..
today, i went and inspected the problem more deligently and found that my clutch slave clylinder was leaking a bit... went to purchase a new one and BAM! problem solved... thank god i didnt buy the clutch.. and thank you for everyone's help!</TD></TR></TABLE>
Ef4doorwagon
Nov 28, 2014 10:17 PM
6thgenftw
Transmission & Drivetrain
Sep 15, 2012 06:36 AM
lokodog
Dec 25, 2005 09:39 PM
eMbrace
May 14, 2005 07:47 AM
Taikonaut
Dec 15, 2003 04:37 PM
