Where is the oil pressure sensor for d16?
Old Aug 21, 2007 | 09:55 PM
SoHc Ej1's Avatar
Default Where is the oil pressure sensor for d16?
Anyone have any pics or knowledge of where the oil pressure sensor is at on a jdm zc(d16)?
Old Aug 21, 2007 | 10:41 PM
951kseries's Avatar
Default Re: Where is the oil pressure sensor for d16? (SoHc Ej1)
back of block, near oil filter, rubber boot over it
if you dont work out alot )if your arms arent buff as expletive) you can snake your arms up to where it is a remove it
i have that snap on adustable socket wrench that can turn or fold into its self and a nice deep socket will get it
otherwise use a racheting box end to get it with ease
Modified by 951kseries at 5:44 PM 8/22/2007
Old Aug 22, 2007 | 08:54 AM
SoHc Ej1's Avatar
Default Re: Where is the oil pressure sensor for d16? (951kseries)
right side of the oil filter?
Old Aug 22, 2007 | 09:00 AM
hondamark35's Avatar
should be the only thing going into the block above the oil fiter. it may be just off to one side... but still above it. it's got a single wire going to it.
Old Aug 22, 2007 | 09:15 AM
SoHc Ej1's Avatar
Default Re: Where is the oil pressure sensor for d16? (hondamark35)
ok i'll take a look
Old Aug 22, 2007 | 03:27 PM
SoHc Ej1's Avatar
how would i take it off? I'm installing an oil pressure gauge
Old Aug 22, 2007 | 03:40 PM
98greensi's Avatar
a 15/16 deep socket works, take it out and install a tee fitting put gauge sensor or line on side of tee and the stock pressure sensor on the other end
Old Aug 22, 2007 | 04:20 PM
SoHc Ej1's Avatar
Default Re: Where is the oil pressure sensor for d16? (98greensi)
how would i get to the sensor?Take off the manifold? You where i could get a tee at?
Old Aug 22, 2007 | 04:21 PM
SoHc Ej1's Avatar
It's my first time doing an oil pressure gauge. I'll post pics when im done
velisma
Jan 30, 2010 08:24 PM
zach1288
Jan 5, 2009 11:38 PM
KooK
Nov 26, 2005 05:29 PM
jisecup
Nov 19, 2003 10:00 PM
Canuk_SiR
Aug 1, 2002 12:16 PM
