injector problem????
ok so my car runs fine till i get a CEL, then it wont go above 3500 like its hitting rev limiter??? the code says its something to do with the injectors.. can some one tell me what i can do.. Thanks
Reason for limp mode = the code 16. When there is a problem with any significant parameter, ie your fuel or ignition, the ECU goes into limp mode. It is to keep you from running your car in an extreme condition. A non functioning fuel injector would cause a lean condition/pre ignition condition. Possible catastrophic failure at high rpm's.
Check your injectors with a stethoscope/long screwdriver wile the car is running. You should here a real fast tick...tick...tick. If you do not hear that then the injector is bad and you need to replace it.
