injector problem????
Old Aug 21, 2007 | 08:56 PM
Panda Eg6's Avatar
Default injector problem????
ok so my car runs fine till i get a CEL, then it wont go above 3500 like its hitting rev limiter??? the code says its something to do with the injectors.. can some one tell me what i can do.. Thanks
Old Aug 21, 2007 | 08:58 PM
Panda Eg6's Avatar
Default Re: injector problem???? (Eg2 4 Life)
Btw the motor is a jdm h22a Thanks again!!!!!
Old Aug 22, 2007 | 09:37 AM
Panda Eg6's Avatar
CEL code 16. car spudders at 3500.. what should i do? Thanks
Old Aug 22, 2007 | 09:45 AM
TheMuffinMan's Avatar
He knows where you live!
do you have an accord?
Old Aug 22, 2007 | 09:52 AM
Panda Eg6's Avatar
Default Re: (TheMuffinMan)
yea its a 90 4 door lx
Old Aug 22, 2007 | 10:05 AM
Just checking
I've seen h22 swapped sols which we wouldn't have a clue on.
Revs up to 3500 and has CEL = limp mode would be my guess
Reason for limp mode = ?
Old Aug 22, 2007 | 10:18 AM
GhostAccord's Avatar
Reason for limp mode = the code 16. When there is a problem with any significant parameter, ie your fuel or ignition, the ECU goes into limp mode. It is to keep you from running your car in an extreme condition. A non functioning fuel injector would cause a lean condition/pre ignition condition. Possible catastrophic failure at high rpm's.
Check your injectors with a stethoscope/long screwdriver wile the car is running. You should here a real fast tick...tick...tick. If you do not hear that then the injector is bad and you need to replace it.
Old Aug 22, 2007 | 11:01 AM
Panda Eg6's Avatar
Default Re: (GhostAccord)
yes it was the code 16, and it was the injector. thanks a lot bro :] already up and running
jpelaston
13
Jul 1, 2008 04:59 PM
slow_dx
Feb 11, 2008 08:16 PM
EFz6er
Dec 23, 2004 06:47 PM
Tinker219
Mar 29, 2003 05:49 PM
