Aeromotive frp
The question have anybody run a -8an returne line with the 1301 frp, the return is a -6 i was wondering if i run a -8an would i have to port the little hole inside for more flow?
I just run a -6 all the way through. No problems with my system. I run an Aeromotive A1000 pump with an A1000 regulator that is -10 in and -6 out. I ran the return all the way back to the tank.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rota92 »</TD></TR><TR><TD CLASS="quote">Get a -6 -> -8 adapter if you want to run a -8 return</TD></TR></TABLE>
I have the adapter, my question was if the hole inside of the -6 opening the same as a -8 or do i have to ream it? it looks like a small hole maybe a 1/8'' hole, should i open it up to a 1/4'' to take advantage of the -8.
lol, p/n 13101. Im not talking about the threaded part, if you turn the reg upside down if you look inside the -6 port you will see the hole that the fuel come out of, that hole looks like maybe 1/4". I was asking if i should open that up. I may have found another alternative from extremevtecracing I'll find out tomorrow. My thing was maybe bigger line bigger hole lol.
A -6 line will easily flow 800 lb/hr before it becomes restictive. If you're bypassing more than that, I'd recommend a different valve with a larger bypass orifice so you don't experience pressure creep.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scott@kinsler »</TD></TR><TR><TD CLASS="quote">A -6 line will easily flow 800 lb/hr before it becomes restictive. If you're bypassing more than that, I'd recommend a different valve with a larger bypass orifice so you don't experience pressure creep.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Adriano »</TD></TR><TR><TD CLASS="quote">No porting needed, Just get a -6 to -8 adapter and run your -8 line back to the tank.
Adriano</TD></TR></TABLE>
Thanks alot guys, thats what i wanted to know
j spec
Mar 1, 2007 01:20 PM
The Original Whitey
Welding / Fabrication
27
Dec 18, 2006 05:53 AM
Boosted Chemist
Apr 19, 2006 03:33 AM
Kwuaymaikrup
Feb 10, 2005 11:56 PM
