lag in vtec
i swaped a 99 b16 into my 2000 civic coupe and changed it to obd1 with a jumper harness and running a p72 ecu... well when i hit vtec i can hear it kick in but it has a lag like for example its not pulling harder ...what could cause that?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8082kcoupe »</TD></TR><TR><TD CLASS="quote">i swaped a 99 b16 into my 2000 civic coupe and changed it to obd1 with a jumper harness and running a p72 ecu... well when i hit vtec i can hear it kick in but it has a lag like for example its not pulling harder ...what could cause that?</TD></TR></TABLE>
i highlighted the problem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedooo »</TD></TR><TR><TD CLASS="quote">
i highlighted the problem</TD></TR></TABLE>
X2, hit up the FAQ section and find what ecu is the correct one for the B16
https://honda-tech.com/zerothread?id=810101
I posted it many times, not to hint that you should try using the search option or anything
EF9750
Nov 2, 2007 06:28 PM
Xgen
13
Feb 25, 2006 07:42 AM
