lag in vtec
Old 08-20-2007, 08:30 PM
8082kcoupe's Avatar
Default lag in vtec
i swaped a 99 b16 into my 2000 civic coupe and changed it to obd1 with a jumper harness and running a p72 ecu... well when i hit vtec i can hear it kick in but it has a lag like for example its not pulling harder ...what could cause that?
Old 08-20-2007, 08:31 PM
speedooo's Avatar
Default Re: lag in vtec (8082kcoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8082kcoupe &raquo;</TD></TR><TR><TD CLASS="quote">i swaped a 99 b16 into my 2000 civic coupe and changed it to obd1 with a jumper harness and running a p72 ecu... well when i hit vtec i can hear it kick in but it has a lag like for example its not pulling harder ...what could cause that?</TD></TR></TABLE>
i highlighted the problem
Old 08-20-2007, 08:33 PM
sanegb16's Avatar
use a p30 if you converted it to obd1
or a chipped p28
Old 08-20-2007, 09:00 PM
97Ej6mike's Avatar
Default Re: lag in vtec (speedooo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedooo &raquo;</TD></TR><TR><TD CLASS="quote">
i highlighted the problem</TD></TR></TABLE>
X2, hit up the FAQ section and find what ecu is the correct one for the B16
Old 08-20-2007, 09:01 PM
Ek Forever y0!
Libertariat's Avatar
Default Re: lag in vtec (97Ej6mike)
p72 is a gsr ecu.
the correct ecu for a b16a2 is a P2T
Old 08-20-2007, 09:03 PM
97Ej6mike's Avatar
https://honda-tech.com/zerothread?id=810101
I posted it many times, not to hint that you should try using the search option or anything
dsmh8tr
08-27-2008 07:13 PM
Jax99SI
04-09-2008 12:59 PM
EF9750
11-02-2007 06:28 PM
Xgen
13
02-25-2006 07:42 AM
c_hladilek
09-20-2005 05:52 PM
Quick Reply: lag in vtec
