integra type r lsd
hi guys,
i was wondering, will an integra type r (dc2) lsd work with my 99 civic si axles ?
if so, is it worth getting this lsd?
i'm from south africa by the way.
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by electron_si »</TD></TR><TR><TD CLASS="quote">JDM ITR LSD = NO
USDM ITR LSD = YES</TD></TR></TABLE>
whats the difference?, they both ought to work? unless there is something I dont know. I have jdm itr motor in my ek.
as long as they're b-series axles, they will work. I order LS axles at the autostore.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h8ted ek »</TD></TR><TR><TD CLASS="quote">
as long as they're b-series axles, they will work. I order LS axles at the autostore.</TD></TR></TABLE>
JDM's like 36mm and USDM's like 32mm or some **** to that effect.
I forgot the #'s exactly, but the JDM ones are larger.
Thought the splines are different too or something to the effect. Don't remember exactly, but there's differences.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedooo »</TD></TR><TR><TD CLASS="quote">i was under the impression the trans side of b series axles was alike on all trannies, and the 98 jdm itr had 36 mm hub splines</TD></TR></TABLE>
98-spec JDM axles aare different. However, if he's just buying the Torsen axle unit by itself, that doesn't matter, right?
It'd only matter if he buys a complete transmission.
Am I missing something or being senile?
http://images.google.co.za/img...a%3DN
theres a link of what im buying. will this work in my ek9 si which has a b16a transmission?
thanks for the info thus far
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">That's for a 36mm axle.
So you need a tranny that accepts 36mm axles and you'll need a 5 lug conversion or something that will suit the 36mm hub.</TD></TR></TABLE>
well there is another way he can make it work, but it might be a pain in the *** to do.
use a 36mm on the inner axle and a 32mm on the outer joint. that way it'll fit both ends. the only thing is, he will have to constantly have to have his axles rebuild when the joints go out versus just picking up new ones at the parts store like everyone else.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">use a 36mm on the inner axle and a 32mm on the outer joint. that way it'll fit both ends. the only thing is, he will have to constantly have to have his axles rebuild when the joints go out versus just picking up new ones at the parts store like everyone else.</TD></TR></TABLE>
I could see that sucking when axle/joint components went out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by harta_tec »</TD></TR><TR><TD CLASS="quote">sorry guys, that was dumb
here's the actual lsd i bought
http://cgi.ebay.com/ebaymotors...wItem</TD></TR></TABLE>
not to mention, you will need the bearing to along with the lsd. it would have saved you alot of headaches had you just bought a usdm itr tranny or a eg6 jdm tranny.
both are equipped with lsd and 32mm axles shafts.
I could see that sucking when axle/joint components went out.</TD></TR></TABLE>
tell me about it. i just go and swap mine out at advance when they go bad, at a one time fee.
but if he takes the route suggested, he will have to pay someone to rebuild them everytime, whether he removes the axles himself or not.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by harta_tec »</TD></TR><TR><TD CLASS="quote">okay this kinda sucks .
but thanks for the info guys</TD></TR></TABLE>
sorry for the kind of bad news, you should have emailed the seller, asked him more questions, as well as asking here.
good luck!
good luck!
mortificationrock
Apr 15, 2007 07:38 PM
