Need advice about pistons and rods.
Old Aug 20, 2007 | 07:14 AM
simonEp3's Avatar
Default Need advice about pistons and rods.
I have the factory K20 in my Si, and I was looking at some JE pistons for my car, not really sure which ones I should get. Heres what I've found so far, I would greatly appreciate any advice. Thanks.
http://www.jepistons.com/cat/j...shtml
Old Aug 20, 2007 | 08:15 AM
dmorris05's Avatar
Default Re: Need advice about pistons and rods. (simonEp3)
Try posting in the correct forum there is one for rsx's and ep3's. Your not gonna get much help since ours are all non si's.....
Old Aug 20, 2007 | 10:48 AM
NTCustoms's Avatar
what are you looking to do for your car? all motor? boost? that would really help.
Old Aug 20, 2007 | 11:38 AM
simonEp3's Avatar
Default Re: (NTCustoms)
Well as of right now, I am going for all motor.
Old Aug 20, 2007 | 06:46 PM
NTCustoms's Avatar
look into some higher compression pistons, something around 11.5+, combined with a high compression head gasket, plus your usual bolt ons and cams, you're looking at some great power. oh and don't forget the K-Pro
Old Aug 20, 2007 | 11:03 PM
eMpAtHy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NTCustoms &raquo;</TD></TR><TR><TD CLASS="quote">look into some higher compression pistons, something around 11.5+, combined with a high compression head gasket, plus your usual bolt ons and cams, you're looking at some great power. oh and don't forget the K-Pro</TD></TR></TABLE>
if hes already going to change the compression with pistons, it would be dumb to change it with a head gasket. those have a greater chance of giving you a difference in compression as opposed to pistons. Stick with the OE head gasket spec and chance compression by either using different valves or pistons.
Old Aug 21, 2007 | 05:05 AM
NTCustoms's Avatar
all i was saying is he could greater increase his compression with a head gasket.
bseriesEF
10
Nov 13, 2006 04:37 PM
Ls InTeGrA RaCeR
Mar 27, 2005 06:07 PM
BLK99VTECR
Jan 19, 2005 06:40 PM
BLK99VTECR
16
Jan 19, 2005 06:32 PM
RuthlessEF-9
May 12, 2004 11:27 AM
