Turbo In + Crusing + Partial Boost = Overheat? Turbo Out + N/A + Full Throttle = Doesn't overheat?
Old Aug 19, 2007 | 05:30 AM
pinoy369's Avatar
Default Turbo In + Crusing + Partial Boost = Overheat? Turbo Out + N/A + Full Throttle = Doesn't overheat?
This is my third turbocharged application and this is the first I have ever experience this.... Now to the questions and my brief story!!
Alright, I got this weird problem. I had my turbo kit in recently. I have a d16z6 with vitaras, eagle rods, kms blockgaurd, cosmetic head gasket, arp head studs, dual core delsol radiator, drag manifold, 38mm tial waste gate, large 6 inch johnny race car inter cooler, turbonetics t3/t4 to4e hybrid, thermostat w few extra holes mod. Anyhow, my question is why am I overheating just cruising at light throttle near 0 psi and into boost? Could it be the intercooler blocking air flow? Could I my timing be too advance? Well the part that gets me is I took the whole kit out and I am N/A until this is solved, but the weird part is that I am no longer overheating while I am N/A 0 to 100% throttle. Why is this? Thanks any help will be appreciated.
Old Aug 19, 2007 | 05:39 AM
highschooler's Avatar
Default Re: Turbo In + Crusing + Partial Boost = Overheat? Turbo Out + N/A + Full Throttle = Doesn't overhe
It probably has to do with your timing.
Old Aug 19, 2007 | 06:53 PM
pinoy369's Avatar
yeah, i will look into it. i basically did a swag on it because i had no lower timing belt cover, so I couldn't do my timing properly. i will keep you guys updated. i was also in in between 11 to 12.5 afr
Old Aug 19, 2007 | 08:07 PM
tony413's Avatar
ywho tuned the car please tell me you didnt just put the kit on the car an driver also you could be facing a number of problems
1. timing
2. fuel
3. inefficent intercooler
Old Aug 19, 2007 | 10:22 PM
Tchleung's Avatar
A turbo is going to put out much more heat then a header, that coupled with an intercooler blocknig airflow to the radiaotr is most likely causing the overheating issues.
Old Aug 20, 2007 | 09:46 AM
bch5428's Avatar
is there a large gap between your intercooler and radiator? i just read a thread on here the other day, it seems the smaller the gap the better between the two, ie <1"
Old Aug 20, 2007 | 02:56 PM
pinoy369's Avatar
Default Re: (bch5428)
The intercooler was flush to the chasis their was really no gap. I cut my bumper out in the shape of my intercooler. As for tuning wise stuff, I was running a SAFCII, an LC-1 with a moates O-meter, 450cc blacktop injectors w/ inline resistors, walbro 255lph fuel pump. afr stayed around 14.7 crusing light throttle. and around 11.5 to 12.5 hitting boost. I would say that I was pretty rich. I am guessing its a timing issue that has to do with the SAFCII. Hmm.. I think I just figured it out. Well next system I am gonna go with is crome pro.
Old Aug 20, 2007 | 03:00 PM
pinoy369's Avatar
Default Re: (pinoy369)
quote from my other post
https://honda-tech.com/zerothread?id=2074474
Old Aug 20, 2007 | 09:16 PM
tony413's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pinoy369 &raquo;</TD></TR><TR><TD CLASS="quote">The intercooler was flush to the chasis their was really no gap. I cut my bumper out in the shape of my intercooler. As for tuning wise stuff, I was running a SAFCII, an LC-1 with a moates O-meter, 450cc blacktop injectors w/ inline resistors, walbro 255lph fuel pump. afr stayed around 14.7 crusing light throttle. and around 11.5 to 12.5 hitting boost. I would say that I was pretty rich. I am guessing its a timing issue that has to do with the SAFCII. Hmm.. I think I just figured it out. Well next system I am gonna go with is crome pro.</TD></TR></TABLE>
there ya go no timing adjustments being made
ludelvr
Sep 6, 2009 05:44 PM
LastGenEK
Feb 10, 2009 02:49 PM
pinoy369
Aug 19, 2007 06:49 PM
Wrath of VTEC
Nov 12, 2003 04:18 AM
crx1856
Aug 19, 2003 04:39 PM
