Map Sensor Code... I need help SEARCHED
Old Aug 18, 2007 | 05:47 PM
nicko360's Avatar
* B A N N E D *
Default Map Sensor Code... I need help SEARCHED
my y7 in an EF is throwing the map sensor (code 3) ive looked for the troubleshooting write up on it, but no luck, ive changed out the map sensor but still have nothing. any help is appreciated. thanks
Old Aug 18, 2007 | 08:38 PM
slowcivic2k's Avatar
Default Re: Map Sensor Code... I need help SEARCHED (nicko360)
Check the wiring and connectors for the sensor in the engine bay and at the ECU, as see if they are broken.
Old Aug 18, 2007 | 10:15 PM
nicko360's Avatar
* B A N N E D *
Default Re: Map Sensor Code... I need help SEARCHED (slowcivic2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowcivic2k &raquo;</TD></TR><TR><TD CLASS="quote">Check the wiring and connectors for the sensor in the engine bay and at the ECU, as see if they are broken.</TD></TR></TABLE>
figured it out... there was a cut wire at the ECU
jus_spooln_wicha
Jun 13, 2007 12:04 PM
krz6jdm
Feb 21, 2006 01:36 AM
DarkBB4
May 8, 2005 09:01 PM
logistixz
Jun 20, 2002 01:06 PM
