Why is my civic bouncing so much? please help
Old Aug 18, 2007 | 05:27 PM
malo11's Avatar
Default Why is my civic bouncing so much? please help
Hey i have a 94 honda civic with stock suspension other than lowering coilovers, after installing the lowering coilovers the car started bouncing too much and reacting too much to bumps and pot holes and little bumps, why is my car bouncing so much?? any ideas???
Old Aug 18, 2007 | 05:30 PM
Padawan's Avatar
Darth ModerVader
Default Re: Why is my civic bouncing so much? please help (malo11)
It's bouncing because the spring rates are too high for the stock dampers, and you have also reduced your overall suspension travel.
Old Aug 18, 2007 | 05:31 PM
ke98248's Avatar
Default Re: Why is my civic bouncing so much? please help (Padawan)
In a few months, your shocks will probably be history.
Old Aug 18, 2007 | 05:35 PM
BlackoutVTi's Avatar
May have likely blown your stock dampers as well. It's critical when looking for a good ride to match good springs in combination with good shocks. With your setup, I can assume that they are not matched too well.
IMO, next spare bit of money you get should go into getting some good shocks for lowered setups, before something gets damaged that you can't replace.
Old Aug 18, 2007 | 05:57 PM
malo11's Avatar
Default Re: Why is my civic bouncing so much? please help (BlackoutVTi)
So do i need to buy aftermarket dampers or aftermarket shocks or what to make it drive as it should...??????
Old Aug 18, 2007 | 06:00 PM
H-T Terminology:
Dampers=Shocks=Struts
Look into what others have found to be good Spring/Strut combos. Not a good thing to cheap out on, but a modest bargain is acceptable.
Old Aug 18, 2007 | 07:03 PM
malo11's Avatar
skunk2??
Old Aug 18, 2007 | 07:05 PM
Skunk2's alright. A little stiff (my experience), but okay. You may want to look into other brands. Skunk2's good, but nothing to write home about in terms of their simple springs.
joshmsartin
Suspension & Brakes
Oct 10, 2009 09:19 AM
BoboyRS
Feb 9, 2009 05:54 AM
TigerLy
Jun 17, 2008 01:07 AM
flyingduck04
Suspension & Brakes
Mar 3, 2006 08:19 AM
drunknmunkypow
Sep 15, 2003 01:34 AM
