Why is my civic bouncing so much? please help
Hey i have a 94 honda civic with stock suspension other than lowering coilovers, after installing the lowering coilovers the car started bouncing too much and reacting too much to bumps and pot holes and little bumps, why is my car bouncing so much?? any ideas???
Darth ModerVader
Re: Why is my civic bouncing so much? please help (malo11)
It's bouncing because the spring rates are too high for the stock dampers, and you have also reduced your overall suspension travel.
Re: Why is my civic bouncing so much? please help (Padawan)
May have likely blown your stock dampers as well. It's critical when looking for a good ride to match good springs in combination with good shocks. With your setup, I can assume that they are not matched too well.
IMO, next spare bit of money you get should go into getting some good shocks for lowered setups, before something gets damaged that you can't replace.
H-T Terminology:
Dampers=Shocks=Struts
Look into what others have found to be good Spring/Strut combos. Not a good thing to cheap out on, but a modest bargain is acceptable.
Skunk2's alright. A little stiff (my experience), but okay. You may want to look into other brands. Skunk2's good, but nothing to write home about in terms of their simple springs.
drunknmunkypow
09-15-2003 01:34 AM
