Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Water Leak
Old Aug 18, 2007 | 10:30 AM
xation's Avatar
Default Water Leak?
I just bought an '04 Civic EX about a week ago and had to take it in for an oil change today, because the drain plug was pretty beat up and I couldn't take it off.
When I got in the car at the lube place I noticed a little puddle of water under the car and I figured maybe they just washed off some oil that had spilled or something.
But after about 2 or 3 hours the thing was still leaking so I decided to take a look and see what it was. I found an open hose thats connected to who knows what. Do you guys have any ideas what the hose is and if its normal for it to be leaking?
http://www.xationworks.com/images/IMG_0134.JPG
http://www.xationworks.com/images/IMG_0125.JPG
http://www.xationworks.com/images/IMG_0120.JPG
http://www.xationworks.com/images/IMG_0117.JPG
This is the new drain plug I had installed, its one of those EZ Drain plug valves or something like that, they sell them at AutoZone. Do you guys know if they are any good?
http://www.xationworks.com/images/IMG_0119.JPG
Thanks
Updated: Removed embedded images and inserted links instead because the images were too large.
Modified by xation at 11:43 AM 8/18/2007
Old Aug 18, 2007 | 10:51 AM
1llmatic's Avatar
New User
Default Re: Water Leak? (xation)
is that water or oil on the ground?
Old Aug 18, 2007 | 10:53 AM
xation's Avatar
Default Re: Water Leak? (1llmatic)
It is water.
Old Aug 18, 2007 | 12:39 PM
LatinEM2's Avatar
my car leaves a little puddle of water every time i run the A/C. Where u using your A/C?
Old Aug 18, 2007 | 12:55 PM
xation's Avatar
Default Re: (LatinEM2)
Yeah... I live in deep south Texas so the AC is always running, it's hot as hell here.
That would be weird if its the AC though, because I have never noticed this before.
Old Aug 18, 2007 | 12:59 PM
LatinEM2's Avatar
Default Re: (xation)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xation &raquo;</TD></TR><TR><TD CLASS="quote">Yeah... I live in deep south Texas so the AC is always running, it's hot as hell here.
That would be weird if its the AC though, because I have never noticed this before. </TD></TR></TABLE>
I can't be hotter than Phoenix AZ Another civic that i had left the same puddle every time i used the AC. So does my bro's Integra's
Old Aug 18, 2007 | 01:58 PM
i-VTEC_DOHC's Avatar
that water is from ur a/c. if u turn on ur fan and go under your car and put your hand on the end of that hose u can feel the air blowing. i kno cuz left my fan on when i changed my oil and i thought my tires were leaking air but it was the hose
Old Aug 18, 2007 | 02:41 PM
xation's Avatar
Default Re: (i-VTEC_DOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i-VTEC_DOHC &raquo;</TD></TR><TR><TD CLASS="quote">that water is from ur a/c. if u turn on ur fan and go under your car and put your hand on the end of that hose u can feel the air blowing. i kno cuz left my fan on when i changed my oil and i thought my tires were leaking air but it was the hose</TD></TR></TABLE>
Yeah, I think you guys are right.
Thanks.
ShadowDaisy82
Jun 20, 2016 09:35 PM
wasrelgood
Jun 22, 2008 03:08 PM
austinkli
Dec 27, 2007 09:50 AM
vietkangta
May 17, 2006 08:28 PM
Cooch2005
Sep 28, 2005 09:14 AM
