Why is this on my crankshaft?
Old Aug 18, 2007 | 10:24 AM
4EN[sic]'s Avatar
Default Why is this on my crankshaft?
On the left is the damaged crank out of my GSR block and on the right is the new Eagle crank I bought to replace it. Why is that dowel there and can I pull it out? My flywheel does not have a hole for that pin. Did I get sent the wrong crank?
Old Aug 18, 2007 | 01:05 PM
4EN[sic]'s Avatar
Default Re: Why is this on my crankshaft? (4EN[sic])
Anyone have an idea?
Old Aug 18, 2007 | 01:09 PM
TooManyTickets's Avatar
The dowel is there to make sure that you put the fly wheel back on the same bolt holes.
like when balancing the crank, you dont need any whieght to be shifted from where it was previously. obviously you could just use a sharpie or something.
remove the dowel if your fly wheel doent have a space for it..
as for getting the wrong crank... dont think you got the wrong part because of that lil nub sticking out
Old Aug 18, 2007 | 01:14 PM
Echo7847's Avatar
Default Re: Why is this on my crankshaft? (TooManyTickets)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TooManyTickets &raquo;</TD></TR><TR><TD CLASS="quote">The dowel is there to make sure that you put the fly wheel back on the same bolt holes.
as for getting the wrong crank... dont think you got the wrong part because of that lil nub sticking out </TD></TR></TABLE>
Old Aug 18, 2007 | 01:37 PM
Default Re: Why is this on my crankshaft? (Echo7847)
ooo a certified ASE cool
Old Aug 19, 2007 | 10:39 PM
4EN[sic]'s Avatar
Anyone else? The stock gsr (I think it is stock) flywheel does not have a hole for this. The pin seems to be pressed in and hole for it does not go through to the other side. I may use some vice grips and just twist it out. Just seems weird that there is a pin but no hole on the flywheel, or the Fidanza one that I bought.
Old Aug 19, 2007 | 10:42 PM
Froth's Avatar
Holy crap pull the pin out and get on with life.
-Froth
Old Aug 19, 2007 | 10:52 PM
4EN[sic]'s Avatar
Default Re: Why is this on my crankshaft? (Froth)
Guess I will pull the pin.
teddy_dc2
Aug 8, 2007 06:37 PM
mar778c
Feb 4, 2007 07:14 PM
johnzm
Jan 24, 2005 05:28 PM
B16A1-EF9
Nov 20, 2004 08:01 AM
Soon_2b_evil
Mar 27, 2004 11:07 AM
