check engine light?
Old Aug 18, 2007 | 06:34 AM
ITRiWISH's Avatar
Default check engine light?
Okay so I can't figure this out really, my check engine light comes on only during the day, but at night it never comes on. And when it's on the VTEC won't engage. Does anyone know what would cause this, or ever heard of this problem at all?
Old Aug 18, 2007 | 10:04 AM
gibsanez's Avatar
Default Re: check engine light? (ITRiWISH)
Why don't you just check the code?
Old Aug 18, 2007 | 11:14 AM
Aristotle's Avatar
If its non OBD sheck the blinking light pattern on the ECU.
Old Aug 18, 2007 | 02:03 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: check engine light? (gibsanez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez &raquo;</TD></TR><TR><TD CLASS="quote">Why don't you just check the code?</TD></TR></TABLE>
x2
The code is what's making your VTEC not work.
Old Aug 19, 2007 | 04:45 AM
gibsanez's Avatar
Default Re: (Aristotle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aristotle &raquo;</TD></TR><TR><TD CLASS="quote">If its non OBD sheck the blinking light pattern on the ECU.</TD></TR></TABLE>
Even the OBD0 cars had the small jumper that made the dash light blink.
Old Aug 19, 2007 | 06:59 AM
VtecSyndrome's Avatar
Default Re: (gibsanez)
Even the OBD0 cars had the small jumper that made the dash light blink.</TD></TR></TABLE>
Actually no they did not (maybe some) at least not most. Why would the ECU need a red light if there was a jumper to make the dash light blink? The jumper was pretty much an OBD 1 feature for the most part.
Old Aug 19, 2007 | 08:55 AM
90_Si's Avatar
There is a jumper under the dash on the passenger side on the bottom right corner under the glove box, put a wire on each side of that and count the blinks on the led on the ecu. Like said before, I dont know of any obd 0s that the dash light blinked on. Also I dont think the non obds have the 10's blink, just ones.
Old Aug 19, 2007 | 09:54 AM
wiZCo's Avatar
Stouts 'n' Scotch
OBD0 ECUs have a red light that blinks on the ECU. No need for jumpering.
Old Aug 27, 2007 | 01:11 PM
ITRiWISH's Avatar
Okay so the car has been converted to OBD1... and it blinks 2 3 6, does anyone know what this means? and how to fix it? because the car sucks to drive.
Old Aug 27, 2007 | 01:53 PM
brokestatusef's Avatar
Default Re: (ITRiWISH)
Ok first off on the matter of the check engine codes just go to google type in "honda check engine codes" save them to your computer for future reffrence
And on the matter of the obdo jumper wire both arguee and arguer could be right my friend had a 91 integra that was obd1 it was a car manufactured late in that year so I have seen a obdo car that was factory obd1 if that makes sense
Old Aug 27, 2007 | 02:57 PM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITRiWISH &raquo;</TD></TR><TR><TD CLASS="quote">Okay so the car has been converted to OBD1... and it blinks 2 3 6, does anyone know what this means? and how to fix it? because the car sucks to drive.</TD></TR></TABLE>
2: #2 Oxygen sensor
3: MAP sensor
6: Water temp. sensor
That is, if you're reading the codes right. There is a difference in the blinks: a long blink=10, a short blink =1.
Old Aug 27, 2007 | 05:24 PM
ITRiWISH's Avatar
is it possible that these could be wired wrong on the swap. because it looks like they made there own harness. I've never messed with an engine swap. or is it possible that these sensors need to be replace. cuz when i bought the car apparently the swap had been recent. and it was someone else's project, and unfortunately i know that means that it's my mess now.. but the car drove solid when i test drove it... but now it drives like ****. hesitates... fuel mixture is lean or rich.... just absolutely horrible...
sublimenerd
Oct 19, 2006 09:11 PM
Baron55
Feb 1, 2006 08:02 AM
willywonka
Jan 12, 2005 05:57 PM
afterburners
Feb 2, 2004 05:18 AM
Defiant1999
Jun 3, 2003 10:41 AM
