Got Some Random Problems With EM1 Need Some Help....
Old Aug 17, 2007 | 07:32 PM
B18Sleeper's Avatar
Default Got Some Random Problems With EM1 Need Some Help....
ok i got 3 problems and i dont know what its doing this so if anyone can help instead of making 3 threads i just made one....
1. My AC isn't blowing any cold air only hot and I cant find the problem
2. My driver side window is not completely in track and i cant get it to go all the way in track it fell out after someone broke into my car and pulled the window almost completely out of the door but now it goes up but i can still barely hear the wind from out while i am driving anyway to fix this besides replacing window tracks?
3. My oil pressure light in my car keeps coming on way before its even close to a oil change and the oil level looks fine so is my car just burning way to much oil and how can i stop that
THANKS
Old Aug 17, 2007 | 08:10 PM
EGLUVN's Avatar
Default Re: Got Some Random Problems With EM1 Need Some Help.... (B18Sleeper)
the ac is probably just empty. i work at a lube shop and we do that kinda thing. prolly cost ya about 150 bucks to get it recharged.
Old Aug 17, 2007 | 08:46 PM
NOFX's Avatar
H-T White Ops
The window problem is a very common problem. Usually the glass slips off of the track on it's own. If you search for "window track" you should get a number of threads as results.
Here's a DIY on taking the door apart.
https://honda-tech.com/zerothread?id=2061336
I'd really suggest that you fix anything broken because it often leads to other parts in the door becoming broken, such as the window motor wearing out.
Old Aug 17, 2007 | 09:00 PM
B18Sleeper's Avatar
Default Re: (NOFX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGLUVN &raquo;</TD></TR><TR><TD CLASS="quote">the ac is probably just empty. i work at a lube shop and we do that kinda thing. prolly cost ya about 150 bucks to get it recharged. </TD></TR></TABLE>
thanks i will look into that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX &raquo;</TD></TR><TR><TD CLASS="quote">The window problem is a very common problem. Usually the glass slips off of the track on it's own. If you search for "window track" you should get a number of threads as results.
I'd really suggest that you fix anything broken because it often leads to other parts in the door becoming broken, such as the window motor wearing out.</TD></TR></TABLE>
i know its comment and i have fixed it put it back in track but its still not going up right....maybe my tracks are bent i dont know....but this problem has been fixed multiple times by putting it back in track and it just wont seal properly
Old Aug 17, 2007 | 09:54 PM
NOFX's Avatar
H-T White Ops
Default Re: (B18Sleeper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Sleeper &raquo;</TD></TR><TR><TD CLASS="quote">thanks i will look into that
i know its comment and i have fixed it put it back in track but its still not going up right....maybe my tracks are bent i dont know....but this problem has been fixed multiple times by putting it back in track and it just wont seal properly</TD></TR></TABLE>
Then the tracks or something else is broken.
Just putting the glass back on the tracks is a temporary solution. There usually seems to be a bigger problem. If you manage to get the glass back on, but haven't fixed anything (i.e., replaced), then I'd suggest not touching that window again until it gets fixed.
Old Aug 17, 2007 | 10:25 PM
B18Sleeper's Avatar
Default Re: (NOFX)
well i cant not roll it down when my ac dont work for anything but i guess i will take it to honda and let then chage me 200 a hour to look at it and fix it in 10 minutes lol....thanks guys
Old Aug 17, 2007 | 10:54 PM
NOFX's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Sleeper &raquo;</TD></TR><TR><TD CLASS="quote">well i cant not roll it down when my ac dont work for anything but i guess i will take it to honda and let then chage me 200 a hour to look at it and fix it in 10 minutes lol....thanks guys</TD></TR></TABLE>
Yeah, my boyfriend's CX didn't come with A/C (nor does it have a moonroof like the Si and EX do) and his passenger window doesn't roll down. The more times he rolls it down, the worse it gets.
Honda charges about $75 an hour I think. And it will take more than ten minutes to fix.
Old Aug 18, 2007 | 08:48 AM
Tonymoto's Avatar
Default Re: (NOFX)
your car sounds like mine em1... My ac went out.. Tried to get it recharged.. said it was the compressor and it needed replacing... And my engine burns an assload of oil.. cause the rings are bad.. Any smoking issues you noticed?
Old Aug 20, 2007 | 08:30 PM
B18Sleeper's Avatar
Default Re: (Tonymoto)
yea well i can get me window back in track in about 10 minutes but if they have to replace the tracks it will take longer....as for the oil problem its making my oil pressure drop and my light is coming on which scares me but i dont really notice any smoking but i know it is happening cause my back bumper is covered from it i am hoping it wont break down before i get a change to rip apart the block and rebuild it from the ground up
EdWord
15
Dec 10, 2009 09:44 PM
wasssup
Dec 1, 2007 08:14 AM
vlc92189
11
Oct 9, 2007 01:16 PM
Markb16a
24
Oct 8, 2007 08:31 PM
mugenspoongsr
May 30, 2005 07:23 PM
