whats the MAX amp when choosing a racing puller fan
Old Aug 17, 2007 | 06:49 PM
IntegraTypeR's Avatar
Default whats the MAX amp when choosing a racing puller fan
Hey guys,
i have this SPAL 13" puller fan which i set up as a pusher....now i have a PWR 1/2 size full race radaitor and since am living in a hot area and the fan am using is not efficient at traffic! leaning towards a racing fan now with the same diammeter size and noticed some racing fans require more Amps ....whats the stock fan amps? now whats the MAX amp i should be looking for? is 9.5A allot to wire it directly to the stock wires?
any pics on how racing fans are setup?
am leaning towards Perma-cool 2950 CFM fan, but dont know if a shroud required to make it work right!
Modified by IntegraTypeR at 4:08 AM 8/19/2007
Old Aug 18, 2007 | 01:42 AM
Default Re: whats the MAX amp when choosing a racing puller fan (IntegraTypeR)
bump
Old Aug 18, 2007 | 03:59 AM
RACEPAK's Avatar
that thing looks dangers whthout a shroud.
Old Aug 18, 2007 | 01:32 PM
Default Re: whats the MAX amp when choosing a racing puller fan (RACEPAK)
hehe yea it even reminds me of horror movies
anyway i remember someone on this forum used it and cant really find any spec on how he set it up.....i dont mind making a shroud as long it works really good! i want something that stays on shorter and doesnt give ECT chances of going up high!
Old Aug 18, 2007 | 02:38 PM
RACEPAK's Avatar
as far as i know if not good to use a puller as a pusher or the other way around.
the blades are good for only one way.
Old Aug 18, 2007 | 03:02 PM
Flashmn's Avatar
racing fan... wow, talk about marketing.
I dont see how "racing fans" differ from normal fans. Just get something that has a high flow rate and you should be fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">that thing looks dangers whthout a shroud. </TD></TR></TABLE>
Yeah, finger-slicer, but alot of old RWD cars had fans without any shrouding.
Old Aug 18, 2007 | 03:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK &raquo;</TD></TR><TR><TD CLASS="quote">as far as i know if not good to use a puller as a pusher or the other way around.
the blades are good for only one way.</TD></TR></TABLE>
well the SPAL am using right is a puller and set as a pusher after i checked its papers and it does say reversable fan...then i noticed that i cant flip the fan since its the type that is pushed in (so i hooked it up and swapped polarity)! anyway i need to upgrade my fan setup to puller now and this fan is not cutting it since its only 920CFM and i believe i need something that flows +2000CFM! noticed the high CFM fans are called racing type!
any suggestions here guys? i need seomthing that flow +2000CFM? any brand/model specs?
i did a search and most slim fans dont go above 1700 CFM (checked Flex A-Lite, SPAL, Summit, Delrale (sp?), Be Cool, Perma-Cool...etc) all +2000 CFM type are racing like the one i linked above!
Modified by IntegraTypeR at 4:25 AM 8/19/2007
Modified by IntegraTypeR at 5:00 AM 8/19/2007
Old Aug 18, 2007 | 03:24 PM
Default Re: whats the MAX amp when choosing a racing puller fan (Flashmn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flashmn &raquo;</TD></TR><TR><TD CLASS="quote">racing fan... wow, talk about marketing.
I dont see how "racing fans" differ from normal fans. Just get something that has a high flow rate and you should be fine.</TD></TR></TABLE>
hehe....thats what they are called on most FAN sites.....these are the only types i found that flow +2000CFM! i did search and if you think theres a slim fan out there that can flow +2000 CFM well am interested to purchase it since i looked everywhere and wasnt successful
i was told that most fan makers dont flow as they state just for advertisement reasons and should look into the fans motor amp draw to know that it will flow more! i could be wrong, but i rather buy something that flows for exmaple 2500CFM and probably only flowing +1900CFM which is in the end better than the 920CFM i have right now! get it?
Old Aug 19, 2007 | 12:53 AM
Flashmn's Avatar
http://www.summitracing.com
have you tried there?
Old Aug 19, 2007 | 01:11 PM
Yep! i mentioned that i checked summit racing!
well lets just say i need +2000 Slim Fan! which brand/model out there that can provide this?
lets just put the similar design of the fans i mentioned above aside for now! wanna hear some slim brands for now
Old Aug 19, 2007 | 02:00 PM
mike1114's Avatar
perm-19008
Summitt.
Make shroud.
Old Aug 19, 2007 | 06:05 PM
Default Re: whats the MAX amp when choosing a racing puller fan (mike1114)
by the way i saw that fan and wanted it and while search i found its not 3000CFM....please look here: http://perma-cool.com/Catalog/Cat_page16.html
the 19008 is actually a 1650CFM!
Spawne32
Oct 4, 2010 06:50 AM
powerdbygarrett
Apr 11, 2009 02:36 PM
1baddturbosi
10
Nov 18, 2007 04:19 PM
deucedeuceEK
Jul 29, 2007 04:16 PM
Fuster_Cluck
Jul 26, 2003 06:57 AM
