Help: Engine valve cover
Old Aug 17, 2007 | 08:52 AM
starcraftbw's Avatar
Default Help: Engine valve cover
When skunk2 cams + stock cam gears installation, do we need to cut off the engine valve cover to make it fit? I really need to know
thanks
Modified by starcraftbw at 10:14 AM 8/17/2007
Old Aug 17, 2007 | 09:04 AM
24TEN's Avatar
PHANTOM MENACE
Default Re: Help: Engine valve cover (starcraftbw)
#1 What is a "cam valve cover"
#2 Why would you need to cut the "cam valve cover" if you have "cams + stock cam gears" installed? Think about it...
#3 Who gave you the idea that it would need to be cut and for what reason?
Old Aug 17, 2007 | 09:15 AM
Default Re: Help: Engine valve cover (24TEN)
^^^I've seen lots of cut engine cover for sale. and wonder if I have to cut mine when I install after market cams.
Old Aug 17, 2007 | 09:45 AM
24TEN's Avatar
PHANTOM MENACE
Ok since you don't get it, people cut the ends off or cut the moon shapes on the ends so they have easy access to adjust their adjustable cam gears.
You stated "cams + stock cam gears," have you figured it out yet?
Old Aug 17, 2007 | 04:52 PM
:D thank you,
So I don't have to cut my since I stay with stock GSR cam gears when install skunk2 cams right?
Old Aug 17, 2007 | 05:32 PM
ekek888's Avatar
the skunk cams or any cam and any adj cam gears will fit inside the the stock valve cover. if u plan to buy adj cam gears, cutting moonshape will make it easier to adj.
Old Aug 18, 2007 | 12:36 AM
OC Geezer's Avatar
Default Re: Help: Engine valve cover (ekek888)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekek888 &raquo;</TD></TR><TR><TD CLASS="quote">the skunk cams or any cam and any adj cam gears will fit inside the the stock valve cover. if u plan to buy adj cam gears, cutting moonshape will make it easier to adj.
</TD></TR></TABLE> Bingo.
Old Aug 18, 2007 | 08:35 AM
King V's Avatar
Default Re: Help: Engine valve cover (OC Geezer)
I want that engine, 24TEN
Old Aug 18, 2007 | 01:04 PM
SD_Lurker's Avatar
HT White Ops
Default Re: Help: Engine valve cover (200kCivicSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 200kCivicSI &raquo;</TD></TR><TR><TD CLASS="quote">I want that engine, 24TEN</TD></TR></TABLE>
Ask Larry @ endyn if you can have it. He is using that picture as a reference.
Old Aug 18, 2007 | 04:58 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: Help: Engine valve cover (SD_Lurker)
LOL Right on, I guess as a mental note, I'll always put a disclaimer when I link pics
Old Aug 18, 2007 | 08:05 PM
Eddiebx's Avatar
not all cam gears clear the plastic upper cover, so sometimes that needs to be cut. though most of them fit fine. i find if there is any interference its mostly the bolts that u use to adjust the gears taht stick out a hair too much and hit the plastic cover.
Suck my DX
May 27, 2005 06:19 PM
Weel
Mar 17, 2004 05:01 PM
vtec69
Oct 31, 2002 06:26 PM
Scary1109
Dec 15, 2001 10:00 AM
JohnnyBoy
Nov 29, 2001 02:53 PM
