What should i do with my
Old Aug 17, 2007 | 06:33 AM
deerman2701's Avatar
Default What should i do with my
99 civic lx, i want to upgrade it, aka boost and the works. But heres the catch, its automatic. Should i even think about upgrading a automatic civic? I mean it wouldnt be that bad would it? I just want more performance it sometimes bogs while going up hills, keep in mind that this is a stock 99 civic lx, i would like some ideas on how i can make it perform better doing easy tasks?
Old Aug 17, 2007 | 06:38 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: What should i do with my (deerman2701)
At least do a 5-speed conversion if you're planning on boosting. Honda Autos are notorious for having issues, especially if they're beaten on.
If you don't want to convert to manual, don't even bother modding your car. With that transmission, it's an 18-second turd.
luckii's Avatar
manual conversion is what u need. hit up the junkyard and find ur year range and get all the parts. probably cost u like $150 or so.
Old Aug 17, 2007 | 06:39 AM
Ron454321's Avatar
Your car should not bog going up a hill, especially in an automatic since it will change the gears for you. Get a tune up, fix your car before you plan on modding it. Automatics are not usually the choice for a modded car, from what I've seen on here the torque convertors don't take well to boost or higher hp.
Old Aug 17, 2007 | 06:45 AM
95ProjectEJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo &raquo;</TD></TR><TR><TD CLASS="quote">At least do a 5-speed conversion if you're planning on boosting. Honda Autos are notorious for having issues, especially if they're beaten on.
If you don't want to convert to manual, don't even bother modding your car. With that transmission, it's an 18-second turd.</TD></TR></TABLE>
x2 ... Modding an automatic seems like a huge waste of time/money. Search around for auto-manual components if you have the money for it and do the swap. That will get put you in the right direction. If you dont have the money then just enjoy the mpg you get and steer clear of hills
Old Aug 17, 2007 | 06:52 AM
Ok thaNKS for the posts hey what can i do other than boosting it to get more performance in the car, i mean it really isnt the fastest of cars, imagine it wouldnt be but it takes hills at 20 mph haha i got the finger quite a few times and almost got assended, i go no cel, nuttin, just got an oil change about july the begin of july that is. What do you suggest to do if i need a "tune up". It moves down hills though , also i dunno if this is the same for all civics of taht model and year but it seems like the gas pedal "jerks" you have to push hard at first and then that makes the car jerk a lot when accelerating, i dunno maybe thats just me thanks guys.
Old Aug 17, 2007 | 06:54 AM
wiZCo's Avatar
Stouts 'n' Scotch
Again, unless you do an auto to manual conversion, any mods on that car are absolutely useless.
You need to have your trans fluid flushed. That is where you should start.
Default Re: (wiZCo)
Ok thanks what would that cost about 120?
Old Aug 17, 2007 | 06:56 AM
Default Re: (deerman2701)
How much for the auto to manual or the trans flush?
Old Aug 17, 2007 | 06:58 AM
Someone told me about 150 for a swap if i go to the junkyard but im thinking of just getting more performance maybe a air filter i dunno what to do im not really trained, for a tranny flush would it be $120?
Old Aug 17, 2007 | 07:06 AM
luckii's Avatar
a manual does give u more performance over automatic.... and better gas milage.
Old Aug 17, 2007 | 07:13 AM
The auto to manual should cost more than 150 in parts alone. Trans, pedal assembly, shift linkage, ECU (chipped or manual) etc. , and the labor should be around 600+
For a auto trans flush that seems about right. I would call around where you live and get prices. Auto flushes are usually a flat rate, call and find the best price that fits your pocket book.
Old Aug 17, 2007 | 07:20 AM
luckii's Avatar
i guess its more expensive there. my friend had his auto oto manual conversion for cheap. maybe it was 300 but 600 is too much to spend i guess on the conversion. get the ls swap for that price. the ls auto tranny swap is cheaper too.
Old Aug 17, 2007 | 07:54 AM
AWD Terror's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deerman2701 &raquo;</TD></TR><TR><TD CLASS="quote">Someone told me about 150 for a swap if i go to the junkyard but im thinking of just getting more performance maybe a air filter i dunno what to do im not really trained, for a tranny flush would it be $120?</TD></TR></TABLE>
This has got to be one of the funnyest things I've read
Old Aug 17, 2007 | 07:59 AM
Default Re: What should i do with my (AWD Terror)
Why is it so funny? Someone said that in a post earlier?
Old Aug 17, 2007 | 08:03 AM
wiZCo's Avatar
Stouts 'n' Scotch
Why is it so funny? Someone said that in a post earlier?</TD></TR></TABLE>
I think he thought it was funny because you keep mentioning "performance" upgrades when I keep telling you that anything you do is useless with an auto.
/thread
Old Aug 17, 2007 | 08:04 AM
jr000's Avatar
i think he meant for the auto to manual swap...not a complete motor swap...
Old Aug 17, 2007 | 08:10 AM
Default Re: What should i do with my (jr000)
Read his newly acquired sig... it was the "performance" part that he found funny as wiZCo said.
An auto-manual swap would be a very realistic upgrade that would create a better platform to work off of. Anything short of that is a waste of time and money IMHO. That 1k you could spend on I/H/E could be better put towards a auto-manual swap.
Old Aug 17, 2007 | 08:26 AM
AWD Terror's Avatar
Default Re: What should i do with my (wiZCo)
/thread</TD></TR></TABLE>
Look in my sig to see why it's funny. It looks like you're saying you will pass on a manual swap for more performance out of an air filter.
BTW air filters give you minimal, if any, gain
2001driver
Honda Civic (2001 - 2005)
Jul 20, 2015 10:55 AM
deerman2701
May 6, 2007 07:11 PM
Joncardi_671
Mar 14, 2004 10:23 AM
CruxJdmB16
Apr 15, 2003 11:12 PM
CheEsEsTeAk168
Feb 13, 2003 08:03 PM
