Help!!! bad ecu?
Old Aug 17, 2007 | 01:22 AM
93sihatchy's Avatar
Default Help!!! bad ecu?
i was driveing when my car just started to idle at 200-500 rpms and would bog on take offs.. i was on the free waay when the car just died. i tryed to pull the codes on my 93 si stock and the ckeck engiane light just stays on im not getting any codes i have done it before, it not getting sprark or fuel..
Old Aug 17, 2007 | 06:31 AM
crazyguy's Avatar
Default Re: Help!!! bad ecu? (93sihatchy)
could be your alternator but u have to push the pin or whatever u are using all the way in the ecu plugs.u will get the code.i tried to get the code for the very frist time and i didnt get the code so i tried to push the pin all the way in and then the cel started to flash.
and also do u have a check battery light on ?
Old Aug 17, 2007 | 03:47 PM
93sihatchy's Avatar
Default Re: Help!!! bad ecu? (crazyguy)
i know tryed all of it the car turn over like it should just not getting spark or fuel the fuel pump is good. dizzy is good just not getting anything and dont know y help me lol......
Old Aug 17, 2007 | 07:05 PM
93sihatchy's Avatar
or could it be the main relay?
Old Aug 17, 2007 | 07:10 PM
funk.regulator's Avatar
Check the voltage of the battery. If its drained, the alternator went bad or a bad ground or connection somewhere. If you think th ecu id bad, pop off the cover and look for burn marks. If something burned, the bottem cover usually has a burn mark on the plastic.
Old Aug 17, 2007 | 07:21 PM
93sihatchy's Avatar
Default Re: Help!!! bad ecu? (funk.regulator)
checked the grounds... pulling the ecu,,, what happens when the main relay gos out? and it cant be the alternatoir or the battrie beciuse it also getting no fuel..
Old Aug 17, 2007 | 07:34 PM
to check the main relay, turn the key. You should a quiet hum while the CEL is on then stops when the CEL turns off. Thats the fuel pump priming.
Old Aug 17, 2007 | 07:37 PM
93sihatchy's Avatar
YEA YEA... it not turning on the fuel pump i hotwired the fuel pump and then it comes on.. it get no fuel or spark or fuel all it does is turn over from the starter.
Old Aug 17, 2007 | 08:02 PM
93sihatchy's Avatar
ttt
Old Aug 17, 2007 | 08:03 PM
How did the ecu look? Thats a lot of stuff to go wrong all at once.
PM sent.
Old Aug 17, 2007 | 08:17 PM
93sihatchy's Avatar
yea u know that y im confused about it. it all got me all confused about it. i got it down to the ecu and the main relay,
Old Aug 18, 2007 | 04:40 AM
93sihatchy's Avatar
bump
Old Aug 18, 2007 | 11:52 AM
93sihatchy's Avatar
bump
Old Aug 18, 2007 | 12:18 PM
93sihatchy's Avatar
help
Old Aug 18, 2007 | 12:31 PM
Targa250R's Avatar
be professional
The main relay controls the power to the ECU and fuel pump.
However, when the main relay fails, it typically fails intermittently in hot weather. Once the car is cooled back down, it should start. Also, the main relay causes a no-fuel condition but the car should still be getting spark.
If you're not getting spark, look elsewhere. You may have a bad ground or some faulty wiring.
Old Aug 18, 2007 | 12:42 PM
93sihatchy's Avatar
Default Re: Help!!! bad ecu? (Targa250R)
the oil light and check eng light just stays on i cant pull any codes i cheked all the grounds.
Old Aug 18, 2007 | 01:05 PM
93sihatchy's Avatar
tttt
Cashkidd720
Honda Civic (2001 - 2005)
Aug 4, 2018 04:30 PM
chasef254
Jun 15, 2015 07:15 PM
DA_9
Mar 11, 2008 03:17 PM
Jonknee
Nov 20, 2006 05:35 PM
Ya wanna race
Apr 5, 2005 05:53 PM
