Pretty CrAp TaStIc 1/4 mile times...
Old Jun 12, 2002 | 09:21 PM
*Boostwerks*'s Avatar
Default Pretty CrAp TaStIc 1/4 mile times...
We'll I was pretty un-impressive.
My best time?
My first run....16.5 at 88MPH.
Here's why...
-NO launch. My stock clutch would have been toast.
-Sipping clutch past 5000 RPM, so I shifted WAY early.
-I ended up in 5th gear to keep the clutch from slipping
-The "ghetto" wastegate ended up giving me 5-6psi at WOT
Doesn't it suck to know that your car can run 13-14's, but because of the stupidest little problems you end up running 16's!!!
AUGGHAUUGUAHAGUAGHAUGHU!!!!!
Oh well....
My day will come...Built ZC
Old Jun 12, 2002 | 09:49 PM
reXem's Avatar
Default Re: Pretty CrAp TaStIc 1/4 mile times... (Bryson)
Wanna give me your ZDyne since you don't seem to be using it j/j too bad....I knew my clutch wouldn't hold once my turbo was on even though it was brand new (4 month old) so I bought a dual friction centerforce clutch....haven't driven my car since it had the new clutch and turbo put on but this weekend I get it and I am going to the track so I will post my times....don't ecpect much my tires suck nuts.....My car is 600kms away getting the work done that is why I haven't driven it yet....been two weeks I am going through withdrawl.....
--reXem
1990 Crx Si
ZC Swap with a turbo at 6psi
Centerforce Dual Friction Clutch
2 1/4" Custom Exhaust
Lowered
Old Jun 12, 2002 | 10:43 PM
Mugen Dom's Avatar
yep i hear ya wanna race my d15 it ran 15.5 last time at the track hehehe NA
Old Jun 12, 2002 | 10:44 PM
Default Re: Pretty CrAp TaStIc 1/4 mile times... (jdmB18hatch)
Well I am also at 5800 ft. up here you would be running...yeah... just about as fast as me!!
Old Jun 12, 2002 | 10:47 PM
Mugen Dom's Avatar
nah should be a bit faster than that even at that elevation have done a few mods since last time and a 2.0 60ft is bad *** with street tires eh oh and a .507 RT
[Modified by jdmB18hatch, 2:47 AM 6/13/2002]
Old Jun 13, 2002 | 07:50 AM
REX VT's Avatar
Learn how to drive....... hehahomuhahaha
[Modified by REX VT, 4:50 PM 6/13/2002]
Old Jun 13, 2002 | 09:27 AM
Default Re: Pretty CrAp TaStIc 1/4 mile times... (REX VT)
True. It was my first time.
But non-the less...my 60 foot's were only 2.5 even with NO launch, and with the correct hard part's I could have easily brought it down.
I could have also brought the time's down IF I had done more run's, but I wanted to save my clutch.
Wanna see my worst time?...
-Launched at 3000. Burned clutch. Didn't even move.
-shifted into second...burned clutch AGAIN.
-shifted BACk into first...and I made a...
YES, I losed to a freaking NEON!!!!!
But this guy didn't make me look too bad...
I did have fun though.
[Modified by Bryson, 10:29 AM 6/13/2002]
[Modified by Bryson, 10:30 AM 6/13/2002]
Old Jun 13, 2002 | 09:36 AM
Soled Out's Avatar
holy ****! i ran a 18.8 when my STD civic was bone stock 235k miles...if i ran a 20sec with ur mods, and get beat by a neon at the same time, i would have shoot myself dead on the spot!
Old Jun 13, 2002 | 09:46 AM
Default Re: Pretty CrAp TaStIc 1/4 mile times... (civic htchbox)
Oh trust me, If I had a gun, I most likely would have.
Old Jun 13, 2002 | 09:49 AM
TheShocker's Avatar
I'm sure I will do the same thing my first time out on the new set-up. Gotta work the kinks out!
Old Jun 13, 2002 | 09:54 AM
JunkeeCrx's Avatar
New User
Default Re: Pretty CrAp TaStIc 1/4 mile times... (TheShocker)
i drive by that track everytime i got home to visit. love that place. right off the freeway/highway.
sorry to hear about that fast neon.......
Old Jun 13, 2002 | 09:58 AM
CWBETB's Avatar
Haha ah well car looks good
I only ran a 16.5 with my ZC the first time out to "Not with the turbo" Its all about expierence. When my brother had his 99si all he could run was a 16.3, then after racing about 10 times he ran mid 15's
Old Jun 13, 2002 | 11:14 AM
Default Re: Pretty CrAp TaStIc 1/4 mile times... (CWBETB)
True.
Then again, your not going to go fast no matter HOW good you are if your car's not working right.
Old Jun 13, 2002 | 11:26 AM
technine's Avatar
Maybe next time you should start in second, then shift into third like at 5000 rpms.
Old Jun 13, 2002 | 01:39 PM
-=TWITCH=-'s Avatar
Default Re: Pretty CrAp TaStIc 1/4 mile times... (technine)
I just went through this with my car I know how it feels man! but Im glad i dont have as much $$ as you do in your ZC dont worry you will get it working like you want it all in time!
Old Jun 13, 2002 | 01:42 PM
REX VT's Avatar
I was just dicking around
Old Jun 13, 2002 | 10:53 PM
Well you had a valid point though. I could have been faster with more practice.
But If I had just 2 working part's on the car(Clutch, wastegate) I could have turned in MUCH better times.
OHHHHHH!!!!! BTW, I forgot to mention(punches himself in the face)...
I did my run's in PART throtal. I didn't run WOT, because the boost kept falling off.
I stayed in Part throtal and got around 7-8psi of boost, but in WOT past 4000RPM the boost would fall like a rock(to around 5-6 psi). Plus if I had run the car in WOT, the clutch wouldn't have held past 5000. I wonder if I would have turned better times running WOT and 5psi then part throtal and 8psi of boost. Unfortunatly I never tried. Oh well.
Damn, I'm shitting my pant's for not mentioning that.
Old Jun 14, 2002 | 04:29 AM
crx(gator)'s Avatar
im jw...why would you go to the track if you knew your car was running 100%...
Old Jun 14, 2002 | 06:32 AM
89 CRX SI's Avatar
Default Re: Pretty CrAp TaStIc 1/4 mile times... (crxgator)
cause its fun and you can see what is not runnning well. Now he found out his cars clutch adn wastegate is screwed
Old Jun 14, 2002 | 08:25 AM
Mugen Dom's Avatar
taking ur car to the track with a bad clutch is a good way to get stuck there
Old Jun 14, 2002 | 11:29 AM
"im jw...why would you go to the track if you knew your car was running 100%..."
Ummmmmm to have fun? Isn't that why were in this Hobby/Lifestyle NE way's?
I did have a lot of fun!! I don't regret going at all.
My freind insisted on going, and I really just wanted to see what It could do before I Finish my ZC build-up.
If I got stuck there oh well. My freind would have towed me home. I have an Exedy clutch waiting to go in with the Built ZC, so If I NEEDED to have the car ready, I would have just swaped in the clutch a little early.
Also, I am not one to worry about something like that. **** happens.
Old Jun 14, 2002 | 03:25 PM
SpooN Man's Avatar
the best I have ran is a 15.5 @95 with a b16a. winter tires and 200,000 miles on the springs and shocks. I am pissed off. 2.4 60 foot need springs badly
[Modified by SpooN Man, 12:25 AM 6/15/2002]
Everyones Hero
Oct 29, 2006 07:45 PM
MysticAzn03
Jan 23, 2003 09:40 AM
ActiveAero
Jan 21, 2003 12:36 AM
Qwikrex
Jul 22, 2002 09:42 AM
