Pad and rotor install
Old Jun 12, 2002 | 09:16 PM
Kamin's Avatar
Default Pad and rotor install
Someone just told me that you shouldnt install pads and rotors at the same time, it could ruin the rotors
is this true?
(i just recieved 2 brembo blanks and axxis ultimate pads with ate superblue fluid)
[Modified by KAMiN, 3:03 AM 6/13/2002]
Old Jun 13, 2002 | 01:39 AM
D16Z6racing's Avatar
Default Re: Pad and rotor install (KAMiN)
I put Brembo C/D rotors on w/ Axxis pads at the same time. No probs here. And they work great!
Old Jun 13, 2002 | 02:02 AM
Kamin's Avatar
Default Re: Pad and rotor install (buster13)
see thats what i thought
but i dunno.
damn friends
anyone else?
Old Jun 13, 2002 | 02:11 AM
travis's Avatar
So you're supposed to keep the old pads for a while with your new rotors and then change? LOL! Or I guess you could put your new pads on, and swap rotors later. Also not likely.
Lightly sand the new rotor to get off any glossy layer from manufacturing (you might not have to do this depending on the rotor) and install the new pads. Make sure you properly bed the pads, let them cool, and you're good to go.
Old Jun 13, 2002 | 03:42 AM
kinesistech's Avatar
Default Re: Pad and rotor install (ITR#231)
New pads and rotors at the same time is good. Sometimes there is a lip on the old rotors, and new pads will drag on them and make noise. New rotors have a coating on them so they dont rust while they're sitting on the shelf. Clean them with brake clean before install.
Old Jun 13, 2002 | 11:26 AM
Kamin's Avatar
Default Re: Pad and rotor install (kinesistech)
ok
got it
now should i got slap my friend upside the head?
Old Jun 13, 2002 | 01:41 PM
travis's Avatar
Naw, they can help you do the swap.
Old Jun 14, 2002 | 10:43 AM
ILUVTEC's Avatar
No, you can install new pads without new rotors everytime. Just check the rotors when you do to see if they should be replaced.
Old Jun 14, 2002 | 11:34 AM
Kamin's Avatar
Default Re: Pad and rotor install (ILUVTEC)
um thanks? if you would have READ my post it said can i replace them both without damaging the new rotor. someone told me it could.
wyee99
Honda Civic (2001 - 2005)
May 13, 2009 03:11 PM
MrIllegalX
12
Feb 24, 2004 10:45 AM
clm
15
Mar 21, 2003 09:48 AM
mr tl
Sep 20, 2002 08:22 PM
mr tl
Dec 5, 2001 07:30 PM
