Why run heater when bleeding coolant?
Old Aug 16, 2007 | 06:38 PM
spidermancivic's Avatar
Default Why run heater when bleeding coolant?
A buddy told me he bleeds the coolant without running the heater on. Says it heats up quicker and the fan turns on quicker. Ive always done it with the heater on. Is there a specific reason why the helms says to run it on?
Old Aug 16, 2007 | 06:45 PM
highrev1987's Avatar
Default Re: Why run heater when bleeding coolant? (spidermancivic)
there could be air in the heater core
Old Aug 17, 2007 | 03:28 AM
EE_Chris's Avatar
Default Re: Why run heater when bleeding coolant? (highrev1987)
You want the heater control **** set to full hot with the fan OFF. This allows coolant to circulate through the heater core where air bubbles can be found, as highrev1987 stated.
Old Aug 17, 2007 | 05:15 AM
AWD Terror's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spidermancivic &raquo;</TD></TR><TR><TD CLASS="quote">A buddy told me he bleeds the coolant without running the heater on. Says it heats up quicker and the fan turns on quicker. Ive always done it with the heater on. Is there a specific reason why the helms says to run it on?</TD></TR></TABLE>
B/c then you know when the thermostat opens.
Old Aug 17, 2007 | 06:12 AM
EE_Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spidermancivic &raquo;</TD></TR><TR><TD CLASS="quote">there a specific reason why the helms says to run it on?</TD></TR></TABLE>
The Helms doesn't say this. But if you have the heater fan on, then it's blowing air across the heater core to get heat inside your car....which removes said heat from the coolant while doing so. You don't want that to happen when you're trying to get the coolant temp hot sooner rather than later.
And the thermostat isn't an on-off switch. It begins to open at ~170*F and is fully opened (1/3") by ~194*F. The radiator fan comes on at ~203*F. So if you let the radiator fan kick on, you can be assured that the thermostat already opened up.
gbg2w1
Aug 30, 2008 05:43 PM
cslegacy
Feb 14, 2008 12:20 AM
aziaticvang
Jan 17, 2008 06:32 PM
importfanatic17
Jan 4, 2007 09:14 PM
fridexter
Nov 20, 2004 02:52 PM
