Help with B18B bogging!!!
Old Aug 16, 2007 | 09:03 AM
redDA90's Avatar
Default Help with B18B bogging!!!
I have a 93 EG four door that I just swapped a B18B (obd-2) in. The car has a OBD 1 wiring harness, and the same stock ECU from the D15B7. The car has little power on take off, but then as I get in the rpm's it boggs the whole way. It will cut off on me when im at idle.
Anyone has a ideas what I can do to fix this problem?
I has a check engine light but I dont have the O2 sensor hook up.
Old Sep 24, 2007 | 08:29 AM
hatchback freek's Avatar
Default Re: Help with B18B bogging!!! (redDA90)
I am having the same problem, except im going from obd2 to obd1, so far i think is a fuel problem, i can only rev mine up with starter fluid. change the fuel pump i guess.
Old Sep 28, 2007 | 03:42 AM
Default Re: Help with B18B bogging!!! (hatchback freek)
should run without the 02
Old Sep 30, 2007 | 05:55 PM
make sure that your distrubutor is hooked up right.
Old Sep 30, 2007 | 06:50 PM
Hondaruss's Avatar
first thing i would check the light see what codes it is throwing dont assume its JUST the 02 find out for sure.. post your findings and will help further. Kinda sounds like you have the TPS and the MAP backwards.
zcoffey
Jan 28, 2011 05:38 AM
Sprocksilvia
14
Jun 23, 2010 09:59 AM
redDA90
Aug 16, 2007 09:02 AM
