Need alittle help!
Need alittle help!
I have a 93 EG four door that I just swapped a B18B (obd-2) in. The car has a OBD 1 wiring harness, and the same stock ECU from the D15B7. The car has little power on take off, but then as I get in the rpm's it boggs the whole way. It will cut off on me when im at idle.
Anyone has a ideas what I can do to fix this problem?
I has a check engine light but I dont have the O2 sensor hook up.
Re: Need alittle help! (civicracer94)
no I havent yet... but does it matter that I the ecu that im running is from a single cam? Or they still have the same fuel map.
FRKWOO
01-07-2009 08:02 PM
