Need alittle help!
Old Aug 16, 2007 | 06:18 AM
redDA90's Avatar
Default Need alittle help!
I have a 93 EG four door that I just swapped a B18B (obd-2) in. The car has a OBD 1 wiring harness, and the same stock ECU from the D15B7. The car has little power on take off, but then as I get in the rpm's it boggs the whole way. It will cut off on me when im at idle.
Anyone has a ideas what I can do to fix this problem?
I has a check engine light but I dont have the O2 sensor hook up.
Old Aug 16, 2007 | 08:57 AM
redDA90's Avatar
Default Re: Need alittle help! (redDA90)
anyone...
Old Aug 16, 2007 | 09:00 AM
civicracer94's Avatar
have you checked the codes??
Old Aug 16, 2007 | 09:02 AM
redDA90's Avatar
Default Re: Need alittle help! (civicracer94)
no I havent yet... but does it matter that I the ecu that im running is from a single cam? Or they still have the same fuel map.
cj90si
Nov 15, 2012 01:10 PM
91whitecivic
Mar 6, 2011 10:06 AM
FRKWOO
Jan 7, 2009 08:02 PM
redDA90
Sep 30, 2007 06:50 PM
bseries_beast
Mar 22, 2007 06:20 AM
