fuel filter
Old Aug 16, 2007 | 05:29 AM
integ_lude's Avatar
Default fuel filter
Ok as some of you know I have been starting my 100,000 tuneup. This involves the timing belt, water pump, belts, spark plugs, wires, dist cap, cold air intake, fuel filter. I have two questions I know I sound like a newb asking these...well I am a newb so here it goes I replaced the plugs, wires, dist cap but when it comes to replacing the fuel filter I cannot seem to get the bolts off. Is there any tricks I need to know about? I feel like I am going to break the fuel line. My last question is, do you think a cold air induction is a huge increase from stock? Or do I need more parts to get the power out of the intake? Basically if I want to mod my car where do I start?
Thanks guys!
Old Aug 16, 2007 | 05:35 AM
integra15's Avatar
Default Re: fuel filter (integ_lude)
Have you used the crow foot wrench?
I tried to get mine off about a year ago but gave up because it felt like I might damage the fuel line. So I guess I am in the same boat as you.
Old Aug 16, 2007 | 05:47 AM
117's Avatar
117
Is this for a 5Gen Prelude? If so, you need to use a flare crows foot. If you use a regular crows foot, you'll likely round the hex fitting because it's made of soft metal (brass more than likely). If you do it exactly as shown in the Helms manual, it's actually not that bad of a job. Just use two flare crows feet as shown, and it'll you'll be able to loosen the fittings. The top fitting is pretty easy, just make sure you replace the two crush washers to ensure there are no leaks when you install the new filter.
I've done two or three, and it's not as bad as everyone says, except on the SH!
Old Aug 16, 2007 | 05:55 AM
bluedlude's Avatar
Default Re: (117)
yeah, i had trouble my first time. i loosened the fuel filter then tried loosening the fittings. i got no where and was scared as hell i was going to bend my lines. then i realized if you leave the filter in its clamp and loosen the fittings first it makes all the difference.
Old Aug 16, 2007 | 06:55 AM
integ_lude's Avatar
Default Re: (117)
It is a 5th gen but does anyone have the helms manual image, if not where could I get a helms manual? I have always wanted one of those.
Thanks guys!
Old Aug 16, 2007 | 06:57 AM
Revi's Avatar
Default Re: (117)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 117 &raquo;</TD></TR><TR><TD CLASS="quote">Is this for a 5Gen Prelude? If so, you need to use a flare crows foot. If you use a regular crows foot, you'll likely round the hex fitting because it's made of soft metal (brass more than likely). If you do it exactly as shown in the Helms manual, it's actually not that bad of a job. Just use two flare crows feet as shown, and it'll you'll be able to loosen the fittings. The top fitting is pretty easy, just make sure you replace the two crush washers to ensure there are no leaks when you install the new filter.
I've done two or three, and it's not as bad as everyone says, except on the SH!</TD></TR></TABLE>
Actually on my SH the fuel filter was quite easy! I had the motor out!
Old Aug 16, 2007 | 07:00 AM
Hawkze_2.3's Avatar
Default Re: (integ_lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integ_lude &raquo;</TD></TR><TR><TD CLASS="quote">It is a 5th gen but does anyone have the helms manual image, if not where could I get a helms manual? I have always wanted one of those.
Thanks guys!</TD></TR></TABLE>
http://Helminc.com or eBay also has them for a resonable price.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integ_lude &raquo;</TD></TR><TR><TD CLASS="quote">My last question is, do you think a cold air induction is a huge increase from stock? Or do I need more parts to get the power out of the intake? Basically if I want to mod my car where do I start?</TD></TR></TABLE>
An intake will no make a noticable difference in power...bottom line. I would start at the Prelude FAQs and go from there. https://honda-tech.com/zerothread/689805
Old Aug 16, 2007 | 07:17 AM
integ_lude's Avatar
Default Re: (Hawkze_2.3)
thanks guys like always, honda-tech.com is the best place to ask ???'s.
Old Aug 16, 2007 | 08:22 AM
integ_lude's Avatar
They have a lot of manuals is it the honda prelude service manual? It is like $68
Thanks
Old Aug 16, 2007 | 08:34 AM
Hawkze_2.3's Avatar
Yes, you want the 'shop manual' or service manual. Don't get the electrical manual or body repair manual....
Old Aug 16, 2007 | 08:35 AM
RomPirate's Avatar
GOOGLE should help you find the CHEAPEST HELMS manual...
*wink*
Old Aug 16, 2007 | 08:38 AM
integ_lude's Avatar
Default Re: (RomPirate)
K thanks guys, much help.
Old Aug 16, 2007 | 08:40 AM
117's Avatar
117
$68 is cheap. You should price the manuals for a Chevy Tahoe! Helms also publishes their manuals as well.
I know you can find pirated copies. I prefer to have a hardcopy myself.
Old Aug 16, 2007 | 08:44 AM
RubenPrelude's Avatar
Don't be scared. Put a good wrench on the fuel line bolt, and hold with another wrench the bolt of the fuel filter. And make that thing loose..
Old Aug 16, 2007 | 09:43 AM
bluedlude's Avatar
Default Re: (RubenPrelude)
are you not getting my PM's integ_lude?
Old Aug 16, 2007 | 11:02 AM
integ_lude's Avatar
Default Re: (bluedlude)
You mean your post here? I guess I don't know what you mean by PM,
-Logan
Old Aug 16, 2007 | 11:39 AM
bluedlude's Avatar
then you definitely aren't getting them. turn your pop up blocker off for this site.
Old Aug 16, 2007 | 12:11 PM
smo0th's Avatar
Just go to hondahookup.com and join their site. After you become a member there, you can download the entire helms manual from their site.
Old Aug 17, 2007 | 05:00 AM
integ_lude's Avatar
Default Re: (smo0th)
thanks for the info I grabbed it yesterday, I am still looking to get a hard copy. Watch out for admins they don't like users posting free helms.
-Logan
Old Aug 17, 2007 | 05:01 AM
integ_lude's Avatar
bluedlude my popup blocker is not on. Weird I cannot see your posts,
Old Aug 17, 2007 | 06:53 AM
integra15's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integ_lude &raquo;</TD></TR><TR><TD CLASS="quote">bluedlude my popup blocker is not on. Weird I cannot see your posts,
//</TD></TR></TABLE>
Just click the lijnk on the "My Profile" link on the top of the page, they click on the "My IM history" link on that page.
Old Aug 17, 2007 | 10:24 AM
integ_lude's Avatar
Default Re: (integra15)
thanks man
scubacamper
Jan 25, 2013 04:55 AM
csckwade
Dec 28, 2012 11:01 AM
Jayk00CivicEx
Mar 29, 2012 10:49 PM
syvpunk
Jul 29, 2010 04:10 AM
civicstein
Jun 4, 2006 04:21 PM
