Auto to 5 speed
Old Aug 16, 2007 | 01:35 AM
RRBNJ's Avatar
Default Auto to 5 speed
Like the title says, lookin to do a change and I'm woundering what it might put me back as far as time and money goes. Change is on a stock 92 EG. Don't know what motor that is off the dome...
Thanks
-Rob
Old Aug 16, 2007 | 02:29 AM
gotsol607's Avatar
Default Re: Auto to 5 speed (RRBNJ)
well, i tkink its more time than money,unless you do not have a 5spd donar car,the holes are there 4 all 5 spd eq. already, it is just mounting clutch resivor, runing lines 4 slayve cyl.clutch master cyl. all shifter linkege, i found it easier to cut the shifter out, leaveing a plate to bolt down solid. puting in the pedels in is kinda hard due to limited space in my del sol,yours should be easy. what else, i think a auto ecu will work, wait before i tell ya let me check on that, your upper tranny mount will be 2 high 4 the smaller 5 spd, so you will need a custom mount,got mine f/m inovative mounts for like 120 bucks, works perfect, it wont hardley cost ya more than that if ya got a donar car, if not, these are some pretty exp parts, hope something in there was helpfull
perseverance
Mar 1, 2007 07:53 AM
JDM_DC4_Fanatic
Nov 13, 2005 07:11 PM
BenzTek134
Aug 11, 2005 10:02 AM
SiKDeLSoL
Apr 30, 2003 10:00 PM
jwmav04
Jun 25, 2002 10:46 AM
