Hey, to switch from auto to manual....
what fabrications will i need to do? am i going to cut a hole from underneath for the 5-speed or will it be able to fit where the auto shifter was etc...i need to know what to expect, thanks
Re: Hey, to switch from auto to manual.... (SiKDeLSoL)
don't need to cut a hole for the shifter. The hole on your auto chassis is actually bigger than the 5 speed. only thing you have to cut is the upper tranny side engine mount chassis bracket then weld one on from a 5 speed.
Re: Hey, to switch from auto to manual.... (dohcgarage)
actually...*place racing* makes that mount for easy bolt in...beyond the obvious things *pedals, clutch hard lines with reserve tank etc* the change over its not hard...as far as wiring...everything stays the same.. if ya have mo questions PM me...peace
Re: Hey, to switch from auto to manual.... (Kool305)
actually, there will be two holes and you'll need to fabricate something to fill the oval one cause it makes a lot of noise and lets in a lot of hot air....i went with a re-weld and a new bracket straight from honda...40 bills and it took 20 minutes...other than that, the installation of the hydrolic cable (something else you'll need) was kindof a pain in the ***, it has to be fit into and aaround a lot of ****. it also helps if you don't have ABS, if you got any ?'s let me know
alright here is a link on a how to and it will tell you pretty much all you need to know except you need to rewire something if you are keepping the automatic ecu and i dont know what that is cause i did a whole motor swap at the same time so i didnt have to deal with it.
http://www.4bangercity.com/automanual.html
also i currently have for sale the pedal assembly the clutch master cylinder and the clutch lines.
http://cgi.ebay.com/ebaymotors...&rd=1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kool305 »</TD></TR><TR><TD CLASS="quote">...as far as wiring...everything stays the same.. </TD></TR></TABLE>
not the reverse lights..
daniellaruso how much did you spend doin your swap? (just the parts and equipment cause you did it yourself right?) is it worth it?
Re: Hey, to switch from auto to manual.... (prendi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prendi »</TD></TR><TR><TD CLASS="quote">
daniellaruso how much did you spend doin your swap? (just the parts and equipment cause you did it yourself right?) is it worth it?</TD></TR></TABLE>
I just got done doing my auto to manual swap and IMO was very worth it and very simple....for cost, I was lucky and paid a girl $150 to strip everything off of her civic that she totalled...
Re: Hey, to switch from auto to manual.... (95hbMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95hbMatt »</TD></TR><TR><TD CLASS="quote">I was lucky and paid a girl $150 to strip everything off of her civic that she totalled... </TD></TR></TABLE>
DAMN more than lucky.. did you install it yourself also?
DAMN more than lucky.. did you install it yourself also? </TD></TR></TABLE>
Yup, did the motor swap(B18B) and auto to manual swap by myself.....and lovin it! Saved me an assload of money! Only cost me $60 total in bay fees to use the hydrolic lift and every tool imagineable at the hobby shop at the base i'm stationed at!
SprayinCX
10
06-10-2004 11:33 PM
