Short shifter Question?
Old Aug 15, 2007 | 07:06 PM
95sloweg's Avatar
Default Short Shifter Question?
i have a ls vtec sitting around, because the tranny is broke, and it has a short shifter on it. I was wondering if i could unbolt that shifter and bolt it on my d16y6 shift linkage.
Thanks for the help.
Old Aug 15, 2007 | 07:41 PM
gsrhatch2356's Avatar
Default Re: Short Shifter Question? (95sloweg)
I have used swaped over parts from almost every civic that I have owned and never had a problem swapping over the short shifter
Old Aug 15, 2007 | 07:43 PM
95sloweg's Avatar
Default Re: Short Shifter Question? (gsrhatch2356)
im new to this stuff. so your saying that i should be able to use that b series shifter on my d series, right.
Libertariat's Avatar
Ek Forever y0!
A b-series shifter will work fine on a d-series linkage.
my skunk2 is from a "gsr"
Old Aug 15, 2007 | 07:44 PM
mortificationrock's Avatar
Default Re: Short Shifter Question? (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">A b-series shifter will work fine on a d-series linkage.
my skunk2 is from a "gsr"</TD></TR></TABLE> So you guys are saying that you can use a B series shifter on a D series tranny with no modification?
Old Aug 15, 2007 | 07:48 PM
Ek Forever y0!
Default Re: Short Shifter Question? (mortificationrock)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mortificationrock &raquo;</TD></TR><TR><TD CLASS="quote"> So you guys are saying that you can use a B series shifter on a D series tranny with no modification? </TD></TR></TABLE>
I've always heard the ITR OEM shifter needs a little modification, but as far as aftermarket shifters, my understanding was that b/d shifters are the same.
Old Aug 15, 2007 | 08:00 PM
95sloweg's Avatar
thanks for the help. ill try to switch to the short shifter when i have the chance later this week.
kpjo4
Oct 3, 2009 04:29 PM
GRAMIREZ5
72
Aug 30, 2007 05:59 AM
THEDirtyDseriesWOOT
Apr 26, 2007 08:56 PM
Sleepy_Red_hatch
Feb 23, 2006 08:08 PM
wowowee
16
Jul 6, 2005 11:13 AM
