external coil
Old Jun 12, 2002 | 04:00 PM
86CRXSi's Avatar
Default external coil
my 1st gen crx has ew4. it has an external ing coil already from factory.
what would it take to replace with aftermarket? has extra wires on it and don't know what there for?
Old Jun 12, 2002 | 05:33 PM
slomofo's Avatar
GDD Member
Default Re: external coil (86CRXSi)
What color are the wires? I can help, I've done it before on an H22A.
Old Jun 12, 2002 | 05:36 PM
86CRXSi's Avatar
Default Re: external coil (slomofo)
can't see it right now, i think one maybe tach and others??????
but this is factory external coil, not like othe "B"'s and stuff.
Old Jun 12, 2002 | 11:02 PM
tinkerbell's Avatar
mate,
i reckon it should be bolt-on.
just make sure before you take hte factory coil off, you mark which wire connects to the + post on the coil and which one is - post
actually, just mark hte + wire so you dont get mixed up
then just disconnect the leads and bolt-in!
then you will be sweet as sugar,
HTH,
t..
Old Jun 12, 2002 | 11:04 PM
tinkerbell's Avatar
Default Re: external coil (tinkerbell)
correction!
the above post only applies if there are 3 wires from your coil:
and spark.
if there are more than these, let us know
t..
vteckilla7
Aug 18, 2004 06:29 AM
AznBlueBoy
Jul 8, 2004 02:25 PM
superturboprelude
Jul 8, 2004 05:10 AM
noslude93
Mar 18, 2003 09:45 PM
Que_Lude
Sep 11, 2002 08:38 PM
