CTR EK cluster in an EG
Old Aug 14, 2007 | 08:25 AM
.PLUMMM's Avatar
Default CTR EK cluster in an EG
hey guys whats goin on? Ive researched cluster swapping topics and i know that all EG clusters are plug and play with other EG's, but i was thinking of getting a CTR cluster for my eg four door. I was just wondering if this needed a little modification to fit or is it basically plug and play aswell? Any help will be appreciated and also if anyone finds any write ups on this topic, theres nothing like useful links! Thanks again.
Modified by .EGGplant at 10:23 AM 8/14/2007
Old Aug 14, 2007 | 09:28 AM
-Gambit-'s Avatar
Default Re: CTR EK cluster in an EG (.EGGplant)
its not plug and play, you will have to re-pin the connectors to make it work. I searched but i cant find the link that shows the diy.
Old Aug 14, 2007 | 09:34 AM
Aralliius's Avatar
Default Re: CTR EK cluster in an EG (-Gambit-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Gambit- &raquo;</TD></TR><TR><TD CLASS="quote">its not plug and play, you will have to re-pin the connectors to make it work. I searched but i cant find the link that shows the diy. </TD></TR></TABLE>
is this the same for a GSR cluster swap?
Old Aug 14, 2007 | 10:35 AM
ru7's Avatar
ru7
Search for fitting ITR gauges into EK/EG. In there you have wiring diagrams for both EK and EG. You should than figure out the pin locations.
If i remember right, you will need EK pins also (the plastic that goes into cluster on the back).
Sorry for my English
Edit: I was bored, here you go: https://honda-tech.com/zerothread?id=1053318
Old Aug 15, 2007 | 09:12 AM
.PLUMMM's Avatar
thanks guys!
FTR94EX
14
Jul 31, 2009 10:45 PM
crazyguy
Aug 28, 2007 01:37 AM
egg_baLLa
14
Apr 16, 2004 12:07 AM
SPOON_BeIgHtEeNsEe
Jan 2, 2002 10:25 AM
milo
Dec 23, 2001 02:42 PM
