CTR EK cluster in an EG
hey guys whats goin on? Ive researched cluster swapping topics and i know that all EG clusters are plug and play with other EG's, but i was thinking of getting a CTR cluster for my eg four door. I was just wondering if this needed a little modification to fit or is it basically plug and play aswell? Any help will be appreciated and also if anyone finds any write ups on this topic, theres nothing like useful links! Thanks again.
Modified by .EGGplant at 10:23 AM 8/14/2007
Re: CTR EK cluster in an EG (.EGGplant)
its not plug and play, you will have to re-pin the connectors to make it work. I searched but i cant find the link that shows the diy.
Re: CTR EK cluster in an EG (-Gambit-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Gambit- »</TD></TR><TR><TD CLASS="quote">its not plug and play, you will have to re-pin the connectors to make it work. I searched but i cant find the link that shows the diy. </TD></TR></TABLE>
is this the same for a GSR cluster swap?
Search for fitting ITR gauges into EK/EG. In there you have wiring diagrams for both EK and EG. You should than figure out the pin locations.
If i remember right, you will need EK pins also (the plastic that goes into cluster on the back).
Sorry for my English
Edit: I was bored, here you go: https://honda-tech.com/zerothread?id=1053318
FTR94EX
14
07-31-2009 10:45 PM
crazyguy
08-28-2007 01:37 AM
SPOON_BeIgHtEeNsEe
01-02-2002 10:25 AM
