ctr, gsr, type r clusters
does the ctr cluster plug and play into the 92-95 civic models?
also is the jdm typr r cluster the same wiring splicing as gsr clusters?
Nope they will not plug and play on a EG. you have to get there plugs and wire them up to the EG wires. there are several write up on these SEARCH is your friend
Re: (JDMlifestyle)
yeah i already know how to do the wires for GSR into an EG. wat i was wondering was if the type r would be the same wiring configuration. sorry if any confusion.
Re: (egg_baLLa)
sure you can.
its just as much of a PITA but you can do it.
didnt one of the jdmhondaparts guys do that with a spoon cluster? the green EG?
Re: (ramz7887)
anyone else know if ctr cluster would work on an EG? im trying to find out some info before i settle on either the gsr, type r, or ctr cluster.
Darth ModerVader
Re: ctr, gsr, type r clusters (egg_baLLa)
Why not try a JDM SiR cluster? It will fit perfectly, and the tach's redline is roughly the same (8,200 I believe).
A photo borrowed from inline4:
Modified by Padawan at 10:47 PM 4/15/2004
Im in the process of doing the GSR Cluster ATM. wiring isnt bad. but take your time and be careful. heatshrink or sauder everything dont use electrical tape. the GSR cluster does not fit perfectly if you dont know so im trying to make something to make it fit better. will post a good DIY in a week or so
Yeah if you do the type r cluster swap, write up a diy thread. Or you could just pm step by step..hahahah
SPOON_BeIgHtEeNsEe
01-02-2002 10:25 AM
