looking for diagram - converting obd2 distributor to obd1
i have a obd2 motor and want to use teh distr. in my obd1 car, i was told it can be done. i have a obd1 dist for parts
Wiring Chart ---- OBD1 OBD2 Function
orange -> dark blue CYPP
white -> white CYPG
orange/blue -> green TDCP
white/blue -> red TDCG
blue/green -> yellow CKPP
blue/yellow -> black CKPG
yellow/green -> yellow/green ICM
black/yellow -> black/yellow IGN Output
blue -> blue Tach Output
https://honda-tech.com/zerothread?id=1875909 try this to make it look nice
white -> white CYPG
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7808 »</TD></TR><TR><TD CLASS="quote">ive been searching, dont think im using the right words or somthing</TD></TR></TABLE>
did you even look at the archives
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7808 »</TD></TR><TR><TD CLASS="quote">no i didnt lol. it looks like all the wires on my obd2 distributor are the same color as the obd1, can i just re pin matched colors to the correct plug? </TD></TR></TABLE>
no they're not all the same
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sloshy »</TD></TR><TR><TD CLASS="quote">Wiring Chart ---- OBD1 OBD2 Function
white -> white CYPG
i dont know what thats for but it didnt match my obd1 harness or obd2 dist. plug at all. both were all the same colors, i just switched all the pins from an obd2 dist plug to a obd1 dist plug same spots. car seems to run fine. didnt have cut or solder anything
thanks for helping anyways
white -> white CYPG
</TD></TR></TABLE>i dont know what thats for but it didnt match my obd1 harness or obd2 dist. plug at all. both were all the same colors, i just switched all the pins from an obd2 dist plug to a obd1 dist plug same spots. car seems to run fine. didnt have cut or solder anything
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7808 »</TD></TR><TR><TD CLASS="quote">i have a obd2 motor and want to use teh distr. in my obd1 car, i was told it can be done. i have a obd1 dist for parts</TD></TR></TABLE>
just go to http://www.passwordjdm.com and buy the conversion harness for like 30 bucks saves alot of trouble plus you can go back when you want to with no problems
took 45min of sitting on my *** to re-pin the distributor side plug, didnt touch the car side harness. probly woulda done that but i happen to have a obd1 distributor to jack the plug from
USDM EG
Mar 19, 2014 04:23 AM
vtecftw
12
Aug 24, 2007 06:36 AM
