pistons in b18c1
Old Aug 13, 2007 | 10:10 AM
JDM_EjONE's Avatar
Default b18c1 pistons and b18c5 pistons
ok.. friends got some R pistons and rods he tryin to sell me.. some one told me that b18c1 and b18c5 has the same pistons or rods or somin. but i didnt think so.. second opinion is need..
Old Aug 13, 2007 | 10:24 AM
EG6 Love's Avatar
Default Re: b18c1 pistons and b18c5 pistons (JDM_EjONE)
im pretty sure that u can swap them out....
Old Aug 13, 2007 | 10:40 AM
95ProjectEJ1's Avatar
taken from wike...
B18C1
VTEC
Found in:
1994-2001 Integra GS-R (DC2 & DB8)
Displacement: 1797 cm³
Compression: 10.0:1
Bore: 81 mm (3.189")
Stroke: 87.2 mm (3.433")
Rod Length: 137.9 mm (5.429")
Rod/Stroke Ratio: 1.58
VTEC
Found in: USDM DC2 Integra Type-R (Integra Type-R)
1997-2001 Integra Type-R (**Note: This model was not produced for the 1999 production year)
Compression: 11.0:1
^^ I would imagine that you could swap them out
Old Aug 13, 2007 | 10:49 AM
JDM_EjONE's Avatar
o sorry.. i know u can swap them out. i was just askin what is the same of the two.. like are the rods the same or are the pistons themselves the same.. or completly diferent.. i think different but i was told they was something the same about the two...
Old Aug 13, 2007 | 11:43 AM
pimpinblackcivic's Avatar
can you not see theres a difference in compression between the two?
Old Aug 13, 2007 | 11:46 AM
Default Re: (pimpinblackcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pimpinblackcivic &raquo;</TD></TR><TR><TD CLASS="quote">can you not see theres a difference in compression between the two?</TD></TR></TABLE>
What he is trying to say is that the bore/stroke/rod length are the same between the two, but not the piston height. That will affect your compression
JDM_EjONE's Avatar
yes i do.. but is it the rods a pistons different or just pistons...... calm down pbc. its just a question to clarify what i heard and what i think
Old Aug 13, 2007 | 07:51 PM
doood's Avatar
been there done that
Default Re: (JDM_EjONE)
itr pistons will give you higher compression. rods are slightly different but not enough to warrent switching from one to the other.
Old Aug 14, 2007 | 01:16 PM
i'm calm - rods and crank and the same in physical dimensions only the piston differs so swapping them in results in an increase in compression
Old Aug 14, 2007 | 04:37 PM
JDM_Greg's Avatar
I have ITR pistons and rods in my C1...it works pretty nicely in my opinion
but yes it works
jennsGSR
Aug 16, 2006 12:17 PM
Formula1
Apr 30, 2006 10:19 AM
B18B1DOHC
Sep 16, 2003 10:10 PM
AxznBlitz
Aug 25, 2002 11:54 AM
