Busted Axle and ABS light
Old Aug 13, 2007 | 05:23 AM
aladdin's Avatar
Default Busted Axle and ABS light
The passenger side axle is finished and oil has been leaking from the inboard joint for quite sometimes. Few days ago I started to hear clunking noise when i trun right. The problem is the ABS light comes on now every time when I first move the car and will stay on until i shut off the engine and will not come back on again till i move the car. Does the busted axle have anythine to do with the ABS light?
Old Aug 13, 2007 | 11:15 PM
aladdin's Avatar
Anyone?
Old Aug 14, 2007 | 12:00 AM
dude_123's Avatar
Default Re: Busted Axle and ABS light (aladdin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aladdin &raquo;</TD></TR><TR><TD CLASS="quote">The passenger side axle is finished and oil has been leaking from the inboard joint for quite sometimes. Few days ago I started to hear clunking noise when i trun right. The problem is the ABS light comes on now every time when I first move the car and will stay on until i shut off the engine and will not come back on again till i move the car. Does the busted axle have anythine to do with the ABS light?</TD></TR></TABLE>
The axle have an important thing to do with the ABS error. On the outboard CV joint there is a ABS ring that has teeths on them. If it gets dirty, crack. or missing teeth/s the ABS light will come on. The sensor will pick up a skip and indicates an error.
Old Aug 14, 2007 | 03:56 AM
aladdin's Avatar
Default Re: Busted Axle and ABS light (dude_123)
But the problem is with the inboard and I can't tell any problem associated with the outboard joint.
Old Aug 19, 2007 | 04:48 PM
slowcivic2k's Avatar
Sorry for bringing life to the dead.
It will cause an error for the same reason, when it clunks it accelerates, hits the hub, and then puts power to the tire. An engine detects misfire on the same principle, even though if one cylinder misfires one time, you may not notice it, but the ECU will see a distorted waveform because it did not contribute to turning the crank, which slows it down, and marks that cylinder with a misfire.
GraphiteMW
Mar 5, 2007 05:04 PM
Lude454
Sep 1, 2005 03:35 AM
Ideal
Apr 24, 2005 08:12 PM
Rain_man
Aug 28, 2001 12:28 PM
Rain_man
Aug 28, 2001 04:32 AM
