vx wiring harness is it junk?or coule it be usted?
Old Aug 12, 2007 | 11:02 AM
lshatch1.8's Avatar
Default vx wiring harness is it junk?or could it be used?
so i got this vx wiring harness ( didnt find out it was a vx till i got it and resold it ) well now i have it just sittin here.. i mean its all ready wired for vtec so is this harness junk? or can i rewire it some how and make it usefull to use on any obd1 single vtec motor? ive already search and only diffrence it looks like is vx has 5 wire o2 so if i change that to a 4 wire will it be ready to use..? btw this will not be going back into a vx chaisse any help would really help thanks
Old Aug 12, 2007 | 11:04 AM
sageuvagony's Avatar
Default Re: vx wiring harness is it junk?or could it be used? (lshatch1.8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lshatch1.8 &raquo;</TD></TR><TR><TD CLASS="quote">so i got this vx wiring harness ( didnt find out it was a vx till i got it and resold it ) well now i have it just sittin here.. i mean its all ready wired for vtec so is this harness junk? or can i rewire it some how and make it usefull to use on any obd1 single vtec motor? ive already search and only diffrence it looks like is vx has 5 wire o2 so if i change that to a 4 wire will it be ready to use..? btw this will not be going back into a vx chaisse any help would really help thanks</TD></TR></TABLE>
But you resold it so it shouldn't matter.
Old Aug 12, 2007 | 01:19 PM
lshatch1.8's Avatar
Default Re: vx wiring harness is it junk?or could it be used? (sageuvagony)
it does matter since i have it now and would like to get use out of it rather than have it just laying around BUMP for some good info
Old Aug 12, 2007 | 02:05 PM
lshatch1.8's Avatar
my buddy said just get rid of it instead of messing with it...anyone else want to second that?
Old Aug 12, 2007 | 10:28 PM
lshatch1.8's Avatar
Default Re: (lshatch1.8)
after some searching it looks like i need to change it out to a 4 wire o2 sensor
https://honda-tech.com/zero...age=2
anything else i should do to this harness to make it run on any other car thats not a vx?
Old Aug 13, 2007 | 09:52 AM
lshatch1.8's Avatar
bump bump guys....
Old Aug 13, 2007 | 09:55 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Keep it for harness plugs at the very least. I can't tell you how handy those are to have when you accidentally smash a sensor plug.
Old Aug 13, 2007 | 11:04 AM
lshatch1.8's Avatar
Default Re: (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">Keep it for harness plugs at the very least. I can't tell you how handy those are to have when you accidentally smash a sensor plug. </TD></TR></TABLE> lol yeah i already have a extra one for plus thats were im gettin the 4 wire o2 sensor plug from id just like to make this vx one work for other obd1 cars
Old Aug 13, 2007 | 11:20 AM
mike1114's Avatar
the VX wiring harness is OBD1
Two thing you need to do.
5-4 wire O2 sensor.
Knock sensor, I don't think it has one.
Other than that it is perfect to use on your OBD1 single cam motor. Or even OBD1 DOHC!!
Old Aug 13, 2007 | 11:35 AM
lshatch1.8's Avatar
Default Re: (mike1114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 &raquo;</TD></TR><TR><TD CLASS="quote">the VX wiring harness is OBD1
5-4 wire O2 sensor.
Other than that it is perfect to use on your OBD1 single cam motor. Or even OBD1 DOHC!!</TD></TR></TABLE>
thank you very much on that info i had read something about a knock sensor but wasnt sure... anything else you can think of? any pins to change on the shock tower plugs??
Old Aug 13, 2007 | 11:40 AM
lshatch1.8's Avatar
btw i thot obd1 singles didnt need a knock sensor???
Old Aug 13, 2007 | 12:48 PM
hatch96y7's Avatar
how about an hx harness i have two plugs one is an 8 connector and the other is a 7
they are on the left side right above the tranny and the arent being used.
i went from a y7oin my 96 to a gsr.
so i dont knbow if the mechanic changed my harness or if it was already there
because i cant find the primary o2 senso plug
Old Aug 13, 2007 | 01:56 PM
lshatch1.8's Avatar
Default Re: (hatch96y7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch96y7 &raquo;</TD></TR><TR><TD CLASS="quote">how about an hx harness i have two plugs one is an 8 connector and the other is a 7
because i cant find the primary o2 senso plug</TD></TR></TABLE> the hx is also the same thing....the plug that has 7 wires needs to be changed to a 4 and ran as an o2 sensor i think...
Old Aug 14, 2007 | 01:42 PM
hatch96y7's Avatar
i am just running the lines direct from the ecu to the o2 sensor
EG_BOI6
Aug 13, 2014 03:49 PM
slowbluhatch
Apr 13, 2005 07:34 AM
92hybridAccord
May 6, 2004 12:00 PM
