Push down the clutch, headlight gets brighter, let go and its dim
Old Aug 12, 2007 | 07:58 AM
hatching's Avatar
Default Push down the clutch, headlight gets brighter, let go and its dim
I just noticed that my headlight gets brighter when I push down the clutch to switch gears, it goes back to normal (little dimmer) when I let it go. What can I do?
Old Aug 12, 2007 | 08:25 AM
EG6 Love's Avatar
Default Re: Push down the clutch, headlight gets brighter, let go and its dim (hatching)
in my 92 si when i turn the head lights on the rpms go up jus a lil bit... same as when u turn the ac on.
when u push the clutch in... the rpms drop and if u have a bad relay of some sort that isnt tellin the engine to throttle up jus a lil... u lose power... and brightness
my bros car will run rough when u turn the ac on at idle cause his engine doesnt throttle up like its supposed to.
so its some kinda sensor thing... nothin to worry bout though
Old Aug 13, 2007 | 04:57 PM
hatching's Avatar
What sensor should I be looking for?
Old Aug 13, 2007 | 05:02 PM
xXSilentScreamXx's Avatar
Default Re: (hatching)
ground its a ground
Uncle Ben's
12
Aug 22, 2012 10:42 PM
gnarlycs
34
Jun 20, 2012 08:00 AM
92piece
Jun 8, 2006 07:29 PM
genetsang
Aug 21, 2004 03:38 PM
p0pe
Sep 19, 2003 09:53 AM
