HELP: Boggin only when car is completely warmed up
Old Aug 11, 2007 | 01:19 PM
tealj1's Avatar
Default HELP: Boggin only when car is completely warmed up
Like the title states, i'm having this bogging problem with my car. It seems to only bog when the car is completely warmed up, could it be tps? i just changed out my iac valve and still the same problem, this is a very annoying problem, can any help me plz!
Old Aug 11, 2007 | 08:47 PM
ckyfan87's Avatar
Default Re: HELP: Boggin only when car is completely warmed up (tealj1)
Might be your ignition module. Ignition modules tend to fail once at operating temp. That is the only thing that i know of that causes bogging once warmed up!
Old Aug 12, 2007 | 10:56 AM
tealj1's Avatar
Default Re: HELP: Boggin only when car is completely warmed up (ckyfan87)
awesome thanks for the info man.
Old Aug 12, 2007 | 01:37 PM
tealj1's Avatar
changed that out with a new one and still the same problem, could it be the o2 sensor giving out the wrong fuel mixture?
Old Aug 12, 2007 | 03:02 PM
tealj1's Avatar
need a resolution, i needa resolution!
Old Aug 12, 2007 | 03:42 PM
ckyfan87's Avatar
After that i really dont know.
Old Aug 12, 2007 | 03:45 PM
Luserkid's Avatar
Whats with all these guessing games?
Whats your setup? When did it start happening? For all we know you could be on a chipped ecu and its a lame *** basemap to you could be boosted and dont have a missing link and the ecu is reading more then 0psi causing the bog.
Old Aug 13, 2007 | 03:56 PM
tealj1's Avatar
Default Re: HELP: Boggin only when car is completely warmed up (Luserkid)
sorry for not specifying, well i have a b16, skunk2 intake manifold, intake,headers exhaust, stock virgin jdm p30. the car did this before and i went to the shop and checked it out (this is when i put the stock jdm intake and exhaust back to stock), they fixed it by changing out the map sensor and correcting the tps, before palmdale closed down i switched to my aftermarket intake and my apexi n1 exhaust, and after i did that the car started bogging again.
d17beast
Honda Civic (2001 - 2005)
Aug 18, 2010 12:11 PM
ls_turbo_#97
Engine Management and Tuning
11
Mar 20, 2009 12:08 AM
typesguy
Feb 1, 2004 01:01 PM
deviant94ex
Jan 2, 2002 05:30 PM
