OBD2 distributor on OBD0->OBD1 conversion?
Hello!
I am going to rebuild my OBD0 B16 to the OBD1, I know I need diferent distributor, I have some TD81U laying at home, can I use this one?
I know if I am rebulding OBD2 to OBD1 I dont need to change the distributor.
Can I do it this way?
Thanks for answers!
Thanks for answers!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wheelman-CZ »</TD></TR><TR><TD CLASS="quote">Hello!
Thanks for answers!</TD></TR></TABLE>
TD81U is a 96-98 DOHC VTEC distributor.
You can use this dizzy and it's compatible with OBD1 ecu's, but you just need to change the wiring around to an OBD2 b-series vtec distributor plug on your engine wire harness side. Simply repin by color matching wires.
As an easy alternative if you're afraid to wire yourself, Rywire sells a mini distributor adaptor which will sold your wiring woes:
http://rywire.com/store/obd0-o...f241f
ej8_fredi
Mar 28, 2009 11:10 PM
TougeGroceryGettR
Nov 29, 2006 05:36 PM
adaptor, conversion, convertion, distribitor, distributor, honda, obd, obd0, obd1, obd2, obd2a, obd2b, plug, wire, wiring
