Ok why is this build so SLOW??!
Honda techs help me out here!
i got a b18c1 block with CTR pistons new bearings etc etc, b16 head with 2 layer spoon gasket, stock cams boooo, minor bolt on crap, i finally fixed my timing it is dead on, and i just put in a high comp basemap
finally got 800 or so miles on it so im takin it out for a lil test run
i was running chipped ecu with a p30 base with a vtec engagement of 5700 ( i know its high ididnt pick it)
now that i got this new basemap for a high comp setup basically the same as mine it doesnt feel any different! the only difference is the vtec engagement is at 5300 instead
the car feels slower then my old b16!
my buddys got a ls/vtec with ctr pistons and a gsr head running a stock p30 that pulls WAY more then what i got! and hes running stock injectors with no tune!
wtf is wrong! making me upset
edit
skunk2 intake mani, 345cc prelude injectors b16 tranny with lighten flywheel and exedy stg1 clutch with bout 3k miles on it if that matters
92 octane too!
Modified by preludedriva at 3:31 AM 8/10/2007
edit
92 octane too!
i dont understand why my friends lsvtec with same pistons is making more power untuned with a p30 (b16) basemap though?
bc the more **** you add to an untued can / most of the time all the **** works againsa each other
go tune both of yours and see which one has more hp
and i mean real tune with a dyno/and or street!!!!
none of that ebay eprom ****
but if you do want chips burned look at my sig the guy does great work
just email him with every thing you want
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xXSilentScreamXx »</TD></TR><TR><TD CLASS="quote">bc the more **** you add to an untued can / most of the time all the **** works againsa each other
just email him with every thing you want</TD></TR></TABLE>
k he has the same setup UNTUNED just ls vtec and its way faster for some reason with smaller injectors
2nd its not a ebay chip i messaged one of the crome tuners on here and had him send me a basemap specially for my setup.....i know its not gonna make the biggest difference but i was hoping for a change and the car feels exactly the same when i had the p30 chip in my ecu
i was thinkin bout running ctr cams in it
so a good tune will do the trick? light and day? like i said my car feels slower then my old b16
no two engines perform the same with the same mods.
Little things like variance in casting during the production process all the way to engine wear will affect how the engine runs.
and yes a tune will make her run much better, not only more efficiently but to her full potential.
A food tune is just as individual as the engine it'sself.
yeah i guess im just one of the unfortunant ones lol
well i just called the tuner i got the basemap from at J-K tuning in PA
he says its just a stock GSR basemap set to run 345cc injectors and ignition timing pulled (im assuming retarded) for the high comp
im assuming thats why its running the same as my p30(b16) basemap i had going
least im getting decent mileage in that thing lol
V8K1LLER
22
Jan 25, 2005 08:39 PM
