Ls V-tec
Old Feb 12, 2003 | 03:49 PM
racer4life's Avatar
Default Ls V-tec
friend building a Ls V-tec with ctr pistons what rings should he run?
Old Feb 12, 2003 | 03:55 PM
altoid's Avatar
Default Re: Ls V-tec (racer4life)
ctr
Old Feb 12, 2003 | 04:04 PM
Combustion Contraption's Avatar
i think ur compression ratio is gonna be a bit too high with CTR pistons inside and ls/vtec pretty close to unstreetable, but i could be wrong. what does everyone else think?
Old Feb 12, 2003 | 04:20 PM
Kamin's Avatar
Default Re: Ls V-tec (95LsVtecDragger)
with a gsr head he will be at 12.6:1 with a b16 head he will be at 12.3:1
so its a little high but streetable with good tuning.
Old Feb 12, 2003 | 04:21 PM
infamousALLMTR's Avatar
i think ur compression ratio is gonna be a bit too high with CTR pistons inside and ls/vtec pretty close to unstreetable, but i could be wrong . what does everyone else think?
your wrong he he
Old Feb 12, 2003 | 09:13 PM
racer4life's Avatar
Default Re: Ls V-tec (infamousLSVTEC)
Its always streetabowl Thanks 4 the info. He is going to run b16 head. whats the comp.rate on that?
Old Feb 12, 2003 | 09:16 PM
baonest1's Avatar
Default Re: Ls V-tec (Kamin)
Old Feb 12, 2003 | 09:21 PM
racer4life's Avatar
Thank U
Old Feb 12, 2003 | 09:45 PM
V3locity's Avatar
do everyone and yourself a favor, add this to your favorites:
http://www.c-speedracing.com/howto/c...c/compcalc.php
Old Feb 13, 2003 | 06:38 PM
TiiiteCrX's Avatar
But what about the valve clearence ?
Old Feb 13, 2003 | 09:12 PM
ArinX's Avatar
im going to go with similar setup what exactly do you mean by good tunning?? hit me up on im if ur not too busy thanks.
Old Feb 13, 2003 | 09:27 PM
TimoneX's Avatar
New User
Default Re: Ls V-tec (ArinX)
He means do not let it see a lean mixture or detonation will result. The margin of error with 12.6:1 c/r is small.
Old Feb 14, 2003 | 10:52 AM
ExospeedLsV's Avatar
Well man i have an Lsvtec in a Crx w GSr head ctr cams jdm 4-1 and the compression is not 12.6:1 dont know what peeps r saying?? about that also daily driver no probs... when i just did the block w stock header, head, cams etc i ran 13.2 @102.. I have since upgraded to skunk2 manifold, ctr cams, afc, LSD tranny and JDM 4-1 header. no dyno but halls ***.. no times yet. If u need ne help my Aim is ExospeedLsV... or check out our website at Exospeed.com, we build nething sell nething .. Let me know what u think i can help out w ne questions u need .. Good Luck
Old Feb 14, 2003 | 12:02 PM
TimoneX's Avatar
New User
Default Re: Ls V-tec (ExospeedLsV)
I think it actually works out to 12.3:1ish w/ CTR pistons in an LS/Vtec w/ GSR head. Still it's high enough that you need it tuned properly to avoid a visit from the detonation fairy.
oneslodx
25
Apr 4, 2008 04:44 AM
datnigabluberry
14
Nov 21, 2006 06:34 PM
tunerraceteam
Jan 2, 2006 02:38 PM
-Racer X-
Apr 8, 2002 06:16 PM
