NEw Rough Idle topic. Need answer
Old Aug 9, 2007 | 09:50 AM
Ch3vy3ater's Avatar
Default NEw Rough Idle topic. Need answer
i recently posted on my lopy idle issue. Then I looked at my header and my primary cylinder coating is WAY off color compared to the rest. Could it be an injector? This is on the #1 cyliner closest to FPR. Or is this normal Cuz it actually feels like a fuel or Ecu idle problem.
Old Aug 9, 2007 | 10:22 AM
Relic1's Avatar
if one cylinder is noticably hotter (or colder) than the others then you may have an injector, plug wire, plug, or distributor cap issue.
if you're questioning one injector, switch it with another cylinder, it's an easy task.
Old Aug 9, 2007 | 01:41 PM
Ch3vy3ater's Avatar
Default Re: (Relic1)
I def thin its an injector, cuz the finihs ios wore off, (from an over heat/heatsoak) si i think its lean, or extra fuel burning in exhaust, also extra soot on back bumper, maybe extra fuel or not enough. Im gonna grab another injector from a firend and see what that does.
Old Aug 9, 2007 | 01:46 PM
Egezzy's Avatar
Spongebrad Squarepants
Default Re: NEw Rough Idle topic. Need answer (Ch3vy3ater)
it could be your iacv!
Jmcalderon4617
May 28, 2018 03:22 PM
jonesdesign
Jun 2, 2009 03:36 PM
94_civicEx
May 3, 2006 10:53 PM
Blown90hatcH
Aug 4, 2003 03:40 PM
