Injector duty cycle at idle..
Old Aug 4, 2003 | 07:55 AM
Blown90hatcH's Avatar
Default Injector duty cycle at idle..
Ok, I am reading my injector duty cycle from my AVCR and it says at around 1k rpm that the duty cycle is around 14%. Here is the setup. Hondata. Aeromotive pump, etc. 75lb injectors. 44psi fuel press.
Also, does it matter which side of the injector goes to the ecu signal and which side goes to the resistor box?
Thanks, Jason
Old Aug 4, 2003 | 07:59 AM
R6Elmo's Avatar
Default Re: Injector duty cycle at idle.. (Blown90hatcH)
is this at idle? or are you revving it to 1000rpm. 14% duty cycle i know for certain is a bit on the high side for idle. Idle should be under 10% for sure. I'm sure more guys here can give more insight
Old Aug 4, 2003 | 12:50 PM
Default Re: Injector duty cycle at idle.. (R6Elmo)
Yeah, the idle is around 900-1000 and the duty cycle is around 13-14%. That is the reading on the AVCR.
Jason
Old Aug 4, 2003 | 03:09 PM
MiraiZ's Avatar
mines like at 1.4%...your idle might be a bit high. Do you have a load on your engine...(AC on? headlights on??)
Old Aug 4, 2003 | 03:13 PM
Default Re: Injector duty cycle at idle.. (MiraiZ)
No load at all. Even with the idle that high....would it still be around 13% duty cycle?
And your 1.4% is read off of your AVCR?
Jason
Old Aug 4, 2003 | 03:16 PM
boostaholic's Avatar
Jason, what does your duty cycle read in the hondata?
Old Aug 4, 2003 | 03:30 PM
ladysman's Avatar
Default Re: Injector duty cycle at idle.. (boostaholic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostaholic &raquo;</TD></TR><TR><TD CLASS="quote">Jason, what does your duty cycle read in the hondata?</TD></TR></TABLE>
Yeah, I would look at this too. Mine is like 1% or something really small. If you want, I can look at my datalogs and tell you. This is with 800cc injectors though.
Really though it is WOT that you care about Injector duty cycle.
Old Aug 4, 2003 | 03:40 PM
MiraiZ's Avatar
Default Re: Injector duty cycle at idle.. (ladysman)
I'm still using my 450cc's and read the duty cycle off of my Power FC (which is similar to way the AVC works)
AC does create quite a load and so does the headlights....AC more than anything else though
DaFredsta
Aug 29, 2011 12:21 PM
JAY
Mar 25, 2006 07:31 PM
CRX-ZC
Jun 11, 2005 09:15 AM
Dyzee
Oct 29, 2004 10:27 PM
ATS*Mark
Oct 21, 2004 01:30 AM
