Eagle Rods on my C5 block
I am a noob on this.. I am putting some low compression pistons and eagle h beam rods and was wondering what kind of bearings to use. I know that honda bearings is recommended by eagle but how do i know which bearing to use?
any input is appreciated
Please do your car a favor and take it to an engine builder. They will get the correct bearings. Everything needs to be spec'd out prob with plastigage.
Low Comp? You going turbo I hope?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PM-Performance »</TD></TR><TR><TD CLASS="quote">Please do your car a favor and take it to an engine builder. They will get the correct bearings. Everything needs to be spec'd out prob with plastigage.
Low Comp? You going turbo I hope?</TD></TR></TABLE>
x2 on everything above.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PM-Performance »</TD></TR><TR><TD CLASS="quote">Everything needs to be spec'd out prob with plastigage. </TD></TR></TABLE>
The second oxymoron about plastigauge in two days... must be a sign.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D »</TD></TR><TR><TD CLASS="quote">
The second oxymoron about plastigauge in two days... must be a sign.</TD></TR></TABLE>
Explain more please?
I would go by what is on the block/crank, but depends on I guess how much the crank was touched/worn
I always assumed this was checked with plastiguage.
The motor has never been opened.. everything is in its original form... what i meant to say was.. will the eagle h beam work with the stock bearing?? and plastiguage, do i torque it with one side of the bearing on or how does the process go?? more than likely if i mest up.. i know next time what not to do.. i don't have any of the mirometer or all that fancy measurement tool but i do have plastiguage... thanks for the input
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typeR#1141 »</TD></TR><TR><TD CLASS="quote">The motor has never been opened.. everything is in its original form... what i meant to say was.. will the eagle h beam work with the stock bearing?? and plastiguage, do i torque it with one side of the bearing on or how does the process go?? more than likely if i mest up.. i know next time what not to do.. i don't have any of the mirometer or all that fancy measurement tool but i do have plastiguage... thanks for the input</TD></TR></TABLE>
1) Don't reuse bearings.
2) Building an engine is all about measuring and you don't have "mirometer or all that fancy measurement tool" that is a recipe for a a lot of wasted money.
3) Meow.
3) Meow.
