lsd into a non-lsd...
Old Aug 8, 2007 | 07:18 PM
EK-ek's Avatar
Default lsd into a non-lsd...
Can I put a itr or ctr lsd into a b16 hydro tranny? what parts would i need or would it be just a drop in.
I have searched and found some things but i still need more answeres.
thanks guys
Old Aug 10, 2007 | 09:52 PM
slowcivic2k's Avatar
Default Re: lsd into a non-lsd... (EK-ek)
You will need a 4.4FD GSR/ITR ring gear for that differential, as there are two different style ring gears, B16/LS are the same, GSR/ITR are different.
If you use needle bearings on your differential setting up preload will be a problem. If you have the ball bearing type then you will need to check the diff clearances and make sure they are still within specs.
teg420
Transmission & Drivetrain
Feb 24, 2014 04:30 PM
Hemix
14
Apr 30, 2010 08:07 PM
harta_tec
Jun 20, 2008 11:17 AM
annin
May 4, 2005 07:01 PM
