Speed limiter?
Old Aug 8, 2007 | 01:24 PM
Loumo's Avatar
Default Speed limiter?
I have a CRX with a B16a(JDM motor) and I am wondering if there is any way to remove the speed limiter? I have a VAFC on the car and I thought that would remove it but it still does it at 110MPH. I use the car to do track days with and it sucks only being able to go 110mph on straights. Any way to take it off?
Old Aug 8, 2007 | 02:07 PM
Relic1's Avatar
toss the VAFC and have the car tuned. removing the speed limiter is as simple as a check box.
Old Aug 8, 2007 | 08:04 PM
Loumo's Avatar
Default Re: (Relic1)
what is a check box and how do i remove it? I know the vafc sucks you dont have to tell me that. I am working on a crome ecu, but for now it helps my car some.......i needed to turn the vtec up cause of the cams.
Old Aug 9, 2007 | 07:15 AM
Relic1's Avatar
by check box, I mean a setting in Crome.
(options [F4] - bottom left)
focus on the ECU, it will make a dramatic change in the way the car runs. (provided you tune it of course)
Old Aug 9, 2007 | 03:31 PM
Loumo's Avatar
OK my next question is can crome work on a OBD0 car? that is what my motor is and i think that is the problem.
Old Aug 10, 2007 | 07:45 AM
Relic1's Avatar
Crome is OBD1 only.
there are a few OBD0 editors also. check out http://www.pgmfi.org/forum and search through the OBD0 forum. read and search before asking questions.
EG6sir2seb
Aug 25, 2007 02:42 PM
slowkaos
Feb 26, 2005 01:10 PM
matix
Mar 11, 2004 09:06 AM
CR-V
Jun 25, 2003 10:54 AM
743power
Feb 6, 2003 12:20 AM
