boost gauage wiring
Old Aug 7, 2007 | 08:41 PM
vietelement's Avatar
Default boost gauage wiring
i have a 99-00 ex, and i'm tryin to wire up my boost gauage. i already have the boost vaccum lines hooked up. the only problem i'm having is that i dunno which wire goes to which wire under the steering wheel, to hook it up to so that the light in the gauge turns on when i turn my lights on. i have a faze boost gauge. any help ?
Old Aug 7, 2007 | 08:48 PM
Ramma's Avatar
My way might be considered hack, but i just ran the wire to the driver side parking light fuse. Works good for me.
Old Aug 7, 2007 | 10:27 PM
918eg's Avatar
Default Re: (Ramma)
if you got a harness for your radio you can run the light wire to the harness.for honda it should be the orange wire that says illumination.it only comes on when you turn on your headlight.try that
Old Aug 8, 2007 | 01:30 AM
Honda Gen's Avatar
Default Re: (T28EG)
get a test light or a test meter for this, but the Radio Harness will also work,
you need to find the ignition wire,
Old Aug 8, 2007 | 10:12 AM
918eg's Avatar
Default Re: (ERZperformance.com)
ignition harness is i think to much to play for boost guage.the only time you need to go there is duing turbo timer installation.either the fuse box like ramma mention or the steroe harness for easy access.
Old Aug 8, 2007 | 09:15 PM
Default Re: (918eg)
thank you for your help guys. i will try the radio harness wire
95hondaacc
Feb 11, 2009 06:42 PM
ctownintegra
Jul 18, 2006 08:35 AM
HoNdAeX11
Jul 21, 2003 02:53 PM
sneakypete
Jan 15, 2003 05:42 AM
bretx0r
Audio / Security / Video
Jul 19, 2002 02:25 PM
